How to test email setting for Alerts?
Posted: Sun Jul 03, 2022 10:35 pm
I am using the standard OTGW version with firmware 5.4 (PIC16F88) and web otmonitor v6.1.
Since Google's support for less secure applications has ended, I have set new parameters for the SMTP server (that I use by default for mail communication and for notifications form other systems).
After this change I stopped the otmonitor process and adjusted the pressurelow parameter to 1.6 (the current value is 1.51), saved the changes and restarted the machine with otmonitor.
However, I did not receive any alert mail. My SMTP server supports SSL/TLS communication on port 465 or STARTTLS on port 587.
When I had Gmail SMTP set up, the 587/TLS combination worked.
I have tried all combinations of Port/TLS/SSL settings but it seems that my outgoing mail settings are not working or alert,pressurelow: 1.6 did not occur. I would need to at least be sure that otmonitor can send mail in case of an alert.
How can I send test mail in the OTMonitor web interface?
Thank you.
Ivan.
Thank you.
Ivan.
