iSense Wireless different behavior
Posted: Thu Jul 14, 2022 9:05 pm
At home I have both a wired and a wireless iSense. The wired version works as expected. However, the wireless one only randomly takes over the changes in the room setpoint.
After some time I figured out what the issue is: for the iSense the otgw changes the setpoint to 0 before changing it to the desired value again. However, the wireless thermostat does not copy the override setpoint to the room setpoint immediately. When I make the change manually and I leave (a lot) more time between the different steps, it does work.
I wonder if adding a delay or some other mechanism to make sure the change has gone through. Does anyone have any experience with this thermostat?
