ThermoSmart - unable to change Room setpoint
Posted: Fri Oct 20, 2023 1:58 pm
I have a ThermoSmart thermostat that I would like to control with the Nodo OTGW-kit. Unfortunately, the command to set a new room setpoint appears to be completely ignored.
In this example I try to change the setpoint to 28 degrees. The current setpoint is 15 degrees:
So that's quite ineffective
The current setpoint of 15 degrees seems to get written every 7 seconds(by the ThermoSmart I assume?):
I am a bit confused, because if I understand the Thermostat Matrix correctly, the OTGW should be able to write a new setpoint in combination with a ThermoSmart thermostat.
Any guidance on how to proceed would be greatly appreciated!
13:25:10.106913 TT: 28.00
13:25:10.151910 B40000200 Read-Ack Status: 00000010 00000000
13:25:10.571875 T100E0000 Write-Data Maximum relative modulation level: 0.00
13:25:10.692067 B700E0000 Unk-DataId Maximum relative modulation level: 0.00
13:25:11.054987 T10100F00 Write-Data Room setpoint: 15.00
13:25:11.060960 R00780000 Read-Data Burner operation hours: 0
13:25:11.191055 B407813C6 Read-Ack Burner operation hours: 5062
13:25:11.196788 AD0100F00 Write-Ack Room setpoint: 15.00
13:24:54.541467 T10100F00 Write-Data Room setpoint: 15.00
13:24:54.674133 AD0100F00 Write-Ack Room setpoint: 15.00
13:25:03.054594 T10100F00 Write-Data Room setpoint: 15.00
13:25:03.185547 AD0100F00 Write-Ack Room setpoint: 15.00
