Toon 1 2024
Posted: Sat Jan 27, 2024 12:02 am
by metsys
Hello, please help me.
I am re-reading the array of information on Toon1 and I can't put together a picture of what is relevant for 2024.
I have a Toon1 in which I got root. No problems with this one.
Next
Software version 5.28.9
and then the problem starts
because when I connect vpn I get an error:
WARNING: Your certificate has expired!
It is obvious that the certificate has expired and there is no more access to the quby.
Hence my noob questions:
1) which update script is up to date for 2024 for Toon1?
2) how can I use it and update to the latest supported version without bricking the device?
Thanks in advance for your help and sorry again noob questions.
Re: Toon 1 2024
Posted: Sun Jan 28, 2024 11:38 am
by oepi-loepi
Re: Toon 1 2024
Posted: Mon Jan 29, 2024 2:30 am
by metsys
Thank you very much!
I've done update:
# curl -Nks https://raw.githubusercontent.com/ToonSoftwareCollective/update-rooted/main/update-rooted.sh -o /root/update-rooted.sh
# sh /root/update-rooted.sh
Version: 4.80 - TheHogNL - 03-01-2023
You are currently running version 5.28.9 on a qb2 with flavour uni
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.10.9 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.17.11 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2.11 5.5.7 5.9.6 5.13.9 5.13.12 5.15.6 5.18.8 5.22.14 5.25.8 5.28.6 5.28.9 5.30.4 5.33.9 5.39.7 5.41.1 5.43.2 5.46.4 5.49.4 5.49.7 5.49.16 5.49.19
5.49.19
Alright, I will try to upgrade to 5.49.19
Check vpn.conf
The vpn.conf seems ok, continuing...
This toon contains old VPN certificates. Need to request new certificates!
We are on a Toon 1 so we need to request new certificates before being able to create a VPN connection...
New VPN certificate request created and now sending the request to Eneco...
201Request successful and updating the VPN certificates now...
Tunnel is alive and configured.
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Starting the upgrade prepare option which downloads all necessary files. No upgrade is done yet.
First removing some files to free some disk space. Removed 'ebl' resource files because this toon is using 'base' resource files.
Waiting to finish. Sometimes this takes a minute or two ..
Done preparing.
Are your sure you want to upgrade to 5.49.19 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
Installing curl as in some update it is removed due to buggy dependencies...
Package curl (7.50.0-r0) installed in root is up to date.
Installing QT5 websockets
Installing libqt5websockets5 (5.11.2+git0+e71467cb56-r0) to root...
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.6.0-master-psplash-curl/armv5e/libqt5websockets5_5.11.2+git0+e71467cb56-r0_armv5e.ipk.
Installing libqt5websockets-qmlplugins (5.11.2+git0+e71467cb56-r0) to root...
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.6.0-master-psplash-curl/armv5e/libqt5websockets-qmlplugins_5.11.2+git0+e71467cb56-r0_armv5e.ipk.
Installing libqt5websockets-plugins (5.11.2+git0+e71467cb56-r0) to root...
Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.6.0-master-psplash-curl/armv5e/libqt5websockets-plugins_5.11.2+git0+e71467cb56-r0_armv5e.ipk.
Configuring libqt5websockets-plugins.
Configuring libqt5websockets5.
Configuring libqt5websockets-qmlplugins.
Upgrade done!
Restoring your iptables and passwd files so you can login again after rebooting.
Upgrade is done. However each firmware upgrade will revert the changes to some files needed for a working rooted Toon. Do you want me me to try and fix a few well known issue's for you right now?
yes
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.49.19.
-- Updating custom app toonstore to release 5.1.4 ... DONE
EDITING: Disable add google DNS on top of resolv.conf
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling KPI and weather happ as these are not necessary on rooted toons
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
EDITING: download certificate store pem file
OVPN DISABLED
Everything done! You should reboot now! Do NOT power cycle! Just issue the 'reboot' command in your shell. Power cycling can cause file system problems.
and seems it was everything ok until first reboot.
Right after first reboot graphic menu and response becomes very slow, very very slow.
Then I've done factory reset, setup wifi again, and it also doesn't helps.
what I've done wrong or should do?
Re: Toon 1 2024
Posted: Mon Jan 29, 2024 7:38 pm
by oepi-loepi
Did you also do a power cylcle?
Re: Toon 1 2024
Posted: Tue Jan 30, 2024 7:26 pm
by metsys
A little clarification on the configuration:
I have a Toon 1 with no peripherals - no boiler adapter and no zigbee electricity and gas meter connected.
Yes, I've done several power cylcles at different times. It has nothing to do with this problem. So the problem remains the same.
Over time after rooting I see some recurring problems:
The device is responsive and fast (periodicity is not reliably established ),
but there is no list of apps in the toonstore - the window says 0 apps available.
After 24 hours everything can come back to life by itself, and sometimes only a power cylcle/reset is needed.
Right now I am sitting near the device and it is slowing down again. I took a screenshot of the top.
I also pinged my router.
# ping 192.168.17.1
PING 192.168.17.1 (192.168.17.1): 56 data bytes
64 bytes from 192.168.17.1: seq=0 ttl=64 time=226.060 ms
64 bytes from 192.168.17.1: seq=1 ttl=64 time=114.213 ms
64 bytes from 192.168.17.1: seq=2 ttl=64 time=95.352 ms
64 bytes from 192.168.17.1: seq=3 ttl=64 time=229.085 ms
64 bytes from 192.168.17.1: seq=4 ttl=64 time=127.586 ms
64 bytes from 192.168.17.1: seq=5 ttl=64 time=89.401 ms
64 bytes from 192.168.17.1: seq=6 ttl=64 time=26.485 ms
64 bytes from 192.168.17.1: seq=7 ttl=64 time=26.196 ms
64 bytes from 192.168.17.1: seq=8 ttl=64 time=28.408 ms
64 bytes from 192.168.17.1: seq=9 ttl=64 time=73.397 ms
64 bytes from 192.168.17.1: seq=10 ttl=64 time=198.660 ms
64 bytes from 192.168.17.1: seq=11 ttl=64 time=67.014 ms
64 bytes from 192.168.17.1: seq=12 ttl=64 time=18.654 ms
64 bytes from 192.168.17.1: seq=13 ttl=64 time=136.763 ms
64 bytes from 192.168.17.1: seq=14 ttl=64 time=21.902 ms
64 bytes from 192.168.17.1: seq=15 ttl=64 time=84.132 ms
64 bytes from 192.168.17.1: seq=16 ttl=64 time=20.710 ms
64 bytes from 192.168.17.1: seq=17 ttl=64 time=69.695 ms
64 bytes from 192.168.17.1: seq=18 ttl=64 time=103.047 ms
64 bytes from 192.168.17.1: seq=19 ttl=64 time=19.974 ms
64 bytes from 192.168.17.1: seq=20 ttl=64 time=32.134 ms
64 bytes from 192.168.17.1: seq=21 ttl=64 time=156.621 ms
64 bytes from 192.168.17.1: seq=22 ttl=64 time=13.226 ms
64 bytes from 192.168.17.1: seq=23 ttl=64 time=2.741 ms
64 bytes from 192.168.17.1: seq=24 ttl=64 time=32.422 ms
64 bytes from 192.168.17.1: seq=25 ttl=64 time=2.293 ms
64 bytes from 192.168.17.1: seq=26 ttl=64 time=51.708 ms
64 bytes from 192.168.17.1: seq=27 ttl=64 time=151.911 ms
64 bytes from 192.168.17.1: seq=28 ttl=64 time=217.047 ms
64 bytes from 192.168.17.1: seq=29 ttl=64 time=34.124 ms
64 bytes from 192.168.17.1: seq=30 ttl=64 time=485.766 ms
64 bytes from 192.168.17.1: seq=31 ttl=64 time=18.855 ms
64 bytes from 192.168.17.1: seq=32 ttl=64 time=59.378 ms
64 bytes from 192.168.17.1: seq=33 ttl=64 time=90.996 ms
64 bytes from 192.168.17.1: seq=34 ttl=64 time=90.444 ms
^C
--- 192.168.17.1 ping statistics ---
35 packets transmitted, 35 packets received, 0% packet loss
round-trip min/avg/max = 2.293/91.897/485.766 ms
# opkg list-installed
aws-iot-device-sdk-cpp - 1.4.0-r0
base-files - 3.0.14-r100
base-passwd - 3.5.20-r1
base-qb2-uni - 5.49.19-0
busybox - 1.27.2-r4
busybox-mountall - 1.27.2-r1
busybox-syslog - 1.27.2-r1
bxt - 1.11-master
ca-certificates - 20180409-r1
chrony - 1.27-r1
curl - 7.50.0-r0
directfb - 1.2.8-r1.0
dropbear - 2015.71-r0
firmware-ba - 1.58-master
firmware-ma - 1.157-master
firmware-zwave-ctrlr - 1.51-master
gettext - 0.18-r5
glibc-binary-localedata-de-de - 2.10.1-r37.1
glibc-binary-localedata-en-gb - 2.10.1-r37.1
glibc-binary-localedata-en-us - 2.10.1-r37.1
glibc-binary-localedata-es-es - 2.10.1-r37.1
glibc-binary-localedata-fr-be - 2.10.1-r37.1
glibc-binary-localedata-fr-fr - 2.10.1-r37.1
glibc-binary-localedata-it-it - 2.10.1-r37.1
glibc-binary-localedata-nl-be - 2.10.1-r37.1
glibc-binary-localedata-nl-nl - 2.10.1-r37.1
glibc-gconv - 2.10.1-r37.1
glibc-gconv-iso8859-1 - 2.10.1-r37.1
glibc-localedata-i18n - 2.10.1-r37.1
glibc-localedata-iso14651-t1 - 2.10.1-r37.1
glibc-localedata-iso14651-t1-common - 2.10.1-r37.1
glibc-localedata-translit-circle - 2.10.1-r37.1
glibc-localedata-translit-cjk-compat - 2.10.1-r37.1
glibc-localedata-translit-compat - 2.10.1-r37.1
glibc-localedata-translit-font - 2.10.1-r37.1
glibc-localedata-translit-fraction - 2.10.1-r37.1
glibc-localedata-translit-narrow - 2.10.1-r37.1
glibc-localedata-translit-neutral - 2.10.1-r37.1
glibc-localedata-translit-small - 2.10.1-r37.1
glibc-localedata-translit-wide - 2.10.1-r37.1
gnupg - 1.4.10-r3
gnutls - 2.10.4-r11.0
gpgme - 1.1.4-r5
gpgv - 1.4.10-r3
happ-eventmgr - 1.270-master
happ-kpi - 1.564-master
happ-pwrusage - 1.879-master
happ-scsync - 1.460-master
happ-smartplug - 1.311-master
happ-thermstat - 1.2427-master
happ-usermsg - 1.157-master
hcb-bxtproxy - 1.1379-master
hcb-comm - 1.223-master
hcb-config - 1.508-48-g3d90-qb2-vpn-cert-regen
hcb-log - 1.126-master
hcb-netcon - 1.546-master
hcb-rrd - 2.234-master
hcb-watchdog - 1.151-master
hdrv-hue - 1.395-master
hdrv-p1 - 1.1092-master
hdrv-zwave - 1.1661-master
i2c-tools - 3.0.3-r0
initscripts - 1.2-r6-runlvls
iptables - 1.4.9.1-r7.1
jansson - 1.3-r1.0
joe - 3.1-r3
kernel - 2.6.36-R10-h28
kernel-image - 2.6.36-R10-h28
kernel-module-fat - 2.6.36-R10-h28
kernel-module-ftdi-sio - 2.6.36-R10-h28
kernel-module-msdos - 2.6.36-R10-h28
kernel-module-pl2303 - 2.6.36-R10-h28
kernel-module-rt5370sta - 2.6.36-R10-h28
kernel-module-rt5370sta-cfg - 2.6.36-R10-h28
kernel-module-rtl8191su - 2.6.36-R10-h28
kernel-module-vfat - 2.6.36-R10-h28
kernel-module-zwave300 - 2.6.36-R10-h28
less - 436-r1
libbz2 - 1.0.6-r0
libc6 - 2.21-r0
libcrypto - 0.9.8m-r14.1
libcrypto1.0.0 - 1.0.2h-r2
libcrypto1.0.2 - 1.0.2p-r0
libcurl - 7.50.0-r0
libcurl4 - 7.65.3-r1
libfreetype6 - 2.5.4-r0
libgcc1 - 4.9.2-r0
libgcrypt - 1.4.1-r0
libgettextlib - 0.18-r5
libgettextsrc - 0.18-r5
libgpg-error - 1.4-r7.1
libhcb-base - 1.463-master
libhcb-boxtalk - 1.211-master
libhcb-com - 1.210-master
libhcb-drv - 1.546-master
libhcb-xml - 1.186-master
libjansson4 - 2.10-r1.0
libjpeg8 - 8d+1.4.0-r0
libnetfilter-conntrack - 0.0.101-r0
libnfnetlink - 1.0.0-r0.0
libopkg - 0.1.8+svns635-r7-gcv
libpcre1 - 8.36-r0
libpng12 - 1.2.44-r3.0
libpng16-16 - 1.6.16-r0
libqt5svg-plugins - 5.11.2+git0+32c93cbca8-r0
libqt5svg-qmlplugins - 5.11.2+git0+32c93cbca8-r0
libqt5svg5 - 5.11.2+git0+32c93cbca8-r0
libqt5websockets-plugins - 5.11.2+git0+e71467cb56-r0
libqt5websockets-qmlplugins - 5.11.2+git0+e71467cb56-r0
libqt5websockets5 - 5.11.2+git0+e71467cb56-r0
libqt5xmlpatterns-plugins - 5.11.2+git0+15e22118d0-r0
libqt5xmlpatterns-qmlplugins - 5.11.2+git0+15e22118d0-r0
libqt5xmlpatterns5 - 5.11.2+git0+15e22118d0-r0
libssl1.0.0 - 1.0.2h-r2
libssl1.0.2 - 1.0.2p-r0
libstdc++6 - 4.9.2-r0
libsysfs - 2.1.0-r3
libuuid1 - 2.25.2-r1-q1
libz1 - 1.2.8-r0
lighttpd - 1.4.35-r6
lighttpd-mod-hcb-web - 1.73-master
lighttpd-module-access - 1.4.35-r6
lighttpd-module-accesslog - 1.4.35-r6
lighttpd-module-auth - 1.4.35-r6
lighttpd-module-compress - 1.4.35-r6
lighttpd-module-dirlisting - 1.4.35-r6
lighttpd-module-indexfile - 1.4.35-r6
lighttpd-module-staticfile - 1.4.35-r6
locale-base-de-de - 2.10.1-r37.1
locale-base-en-gb - 2.10.1-r37.1
locale-base-en-us - 2.10.1-r37.1
locale-base-es-es - 2.10.1-r37.1
locale-base-fr-fr - 2.10.1-r37.1
locale-base-it-it - 2.10.1-r37.1
locale-base-nl-nl - 2.10.1-r37.1
lzo - 1.08-r15
makedevs - 1.0.0-r10
module-init-tools - 3.12-r6
module-init-tools-depmod - 3.12-r6
modutils-initscripts - 1.0-r3
mtd-utils - 1.4.1-r0
ncurses - 5.7+20110115-r16
ncurses-libncurses - 5.7+20110115-r16
ncurses-libtinfo - 5.7+20110115-r16
ncurses-terminfo - 5.7+20110115-r16
ncurses-terminfo-base - 5.7+20110115-r16
netbase - 4.21-r50
openssl - 1.0.2p-r0
openssl-conf - 1.0.2p-r0
openvpn - 2.3.11-r1
opkg-collateral - 1.0-r3
packagegroup-qb2-required - 1.0-r2
packagegroup-qb2-required-priv - 1.0-r1
pointercal - 0.0-r22
psplash - 0.1+git0+14c8f7b705-r15-q18
psplash-quby - 0.1+git0+14c8f7b705-r15-q18
psplash-toon - 0.1+git0+14c8f7b705-r15-q16
pth - 2.0.2-r2
qmf-0 - 1.19-master-r0
qmf-collateral - 1.1-r0
qmf-release - 1.1407-1-g8b57-aaaa-disable-iot
qmf-tenantize - 1.2-r0
qt-gui - 1.9877-master
qtbase - 5.11.2+git0+49efea26a5-r0
qtbase-plugins - 5.11.2+git0+49efea26a5-r0
qtbase-qmlplugins - 5.11.2+git0+49efea26a5-r0
qtdeclarative - 5.11.2+git0+c249438243-r0
qtdeclarative-plugins - 5.11.2+git0+c249438243-r0
qtdeclarative-qmlplugins - 5.11.2+git0+c249438243-r0
qttools-tools-lrelease - 5.11.2+git0+ff440191de-r2
qtvirtualkeyboard - 5.11.2+git0+631b2089bc-r0
qtvirtualkeyboard-plugins - 5.11.2+git0+631b2089bc-r0
qtvirtualkeyboard-qmlplugins - 5.11.2+git0+631b2089bc-r0
readline - 5.2-r8
samba-nmbd - 3.0.20-r8
sysvinit - 2.86-r63-q2
sysvinit-inittab - 2.86-r63
sysvinit-pidof - 2.86-r63
sysvinit-utils - 2.86-r63
tenant-all - 1.185-master
tslib - 1.0-r28.7hae
tslib-calibrate - 1.0-r28.7hae
tslib-conf - 1.0-r28.7hae
tzdata - 2011b-r8.0
tzdata-americas - 2011b-r8.0
tzdata-europe - 2011b-r8.0
update-modules - 1.0-r10
update-rc.d - 0.7-r2
util-linux-uuidgen - 2.25.2-r1-q1
wget - 1.12-r8.2
wireless-tools - 29-r5
wpa-supplicant - 2.6-r0
wpa-supplicant-cli - 2.6-r0
wpa-supplicant-passphrase - 2.6-r0
www-jquery-ui - 1.31-master
www-resources - 1.43-master
zip - 2.32-r2
