Toon 2 (Boxx) water monitoring with analog sensor
If you don't know where to post, post here.
wian
Post by wian »
I have a Belgium Toon 2 (Boxx) with the waterkit. This has a separate port for an analog meter that you connect to your water meter.
It works, when I use water, it is shown on the display.
I would like to pull water consumption statistics into home assistant, but I cannot find the data anywhere. :?: Does one of the devs here have an idea how to access this information from the network?
oepi-loepi
Re: Toon 2 (Boxx) water monitoring with analog sensor
Post by oepi-loepi »
wian
Post by wian »
Thanks oepi-loepi!
I'm not using that add-on, but it contains the URL where the information is pulled from:
http://toon/hdrv_zwave?action=getDevices.json
Variables are "CurrentWaterQuantity" and "CurrentWaterFlow".
According to code the quantity is in liters, but if I leave the tap open for half a minute it doesn't increase. Maybe unit is 10l or maybe my analog sensor is not reading correctly. Anyway, I'm a big step closer :)
SensorEntityDescription(
key="waterquantity",
name="P1 waterquantity",
icon="mdi:water",
native_unit_of_measurement=UnitOfVolume.LITERS,
device_class=SensorDeviceClass.WATER,
state_class=SensorStateClass.TOTAL_INCREASING,
key="waterflow",
name="P1 waterflow",
icon="mdi:water-pump",
unit_of_measurement = "l/m",
state_class=SensorStateClass.MEASUREMENT,
GovertT
Post by GovertT »
Interesting project. Maybe the problem is really with the unit of measurement. Try to check that the analog sensor is correctly set up and is reading the data accurately.
Zoek hier naar de volgende grote overwinning. Dit is jouw sleutel tot onvergetelijke ervaringen en levendige emoties!
Return to “Toon miscellaneous”
