Axis 207W
Posted: Mon Sep 22, 2008 9:04 pm
by TANE
Since few weeks I have a new Axis 207W
quality of this camera is very good.
I like also to use this camera in the dark.
There are no IR leds on this cam.
I found a link on the net that someone has added IR led.
http://www.jasonmacpherson.com/adding-n ... y-monitor/
This is simple...but will not work because of the built in IR filter.
I have tested this and is not usable.
any idea how to remove the IR filter?
I have send few messages to the owner of the link..no response..:(
Axis 207W
Posted: Mon Sep 22, 2008 9:33 pm
by Bastiaan
Just checked with my 207 by pointing a remote control at it in the dark and it clearly shows the LED's.
Meaning there is no IR filter. (would make it very expensive)
Did you test your one?
I have seen several IR lights with a couple of IR LED's in a circle.
Axis 207W
Posted: Mon Sep 22, 2008 9:44 pm
by TANE
Test I have done is using the IR leds of my other camera and point both to the same corner.
207w will show nothing...just to dark.
there is some kind of filter I have also seen this on some other sites
also some special lens for Ir
http://www.webcamcenter.nl/catalog/prod ... d1fd53464f
Axis 207W
Posted: Mon Sep 22, 2008 10:35 pm
by Bastiaan
I know the IR filters from DSLR and Movie DataCamera's. Usually it is a small piece of glass, just in front of the chip. (we call it a 'low-pass' filter.)
Did you take of the lens already?
Your link shows an IR filter housing to hide the camera, they also mention a special IR lens, thats sounds strange to me but it could mean they 'damped' the IR filter straight on the coating of the standard lens. Never heard that it was possible...
So check one: take the lens of and check for any glass in front of the chip. If none, shine your TV remote on the chip and see if it brightens up, then do the same with the lens mounted and you should get all the answers :-)
Axis 207W
Posted: Mon Sep 22, 2008 10:44 pm
by TANE
yep...all strange.
Think I will go for the Y-cam with night view
http://www.networkwebcams.co.uk/product ... cts_id=659
Hope this camera has still image mode for the Pronto and java support
what is positive it work on mobile phone..
Axis 207W
Posted: Tue Mar 03, 2009 1:25 pm
by Paul H te O
Hi Chak,
I have the axis M1031-W the qualty at day time is good, but I want also better night view.
Do you have already a Y-cam, and if so what do you find of the quality of the view at day and night?
Regards Paul.
Axis 207W
Posted: Tue Mar 03, 2009 2:26 pm
by TANE
Hi Paul,
I have few Y-cam's quality is not that good as the Axis but works great in with zero light.
Axis 207W
Posted: Tue Mar 03, 2009 3:02 pm
by Paul H te O
Oke thanks, but you wrote in a another topic about the connection quality that it was not that good did you mean this Y-cam.
Regards Paul.
Axis 207W
Posted: Tue Mar 03, 2009 3:44 pm
by TANE
Connection quality inside is good..this depends also on the AP you are using
Axis 207W
Posted: Wed Mar 04, 2009 2:54 pm
by Paul H te O
Chack, will you do something for me, will you messure the thicknes of the Y-cam knight include the power supply plug.
THNX Paul.
