Powermeter option unavailable Toon1
Forum about Toon hardware, both versions 1 and 2 of Toon
Pochoto2
Post by Pochoto2 »
Hi there,
I have a Qubino energy meter to measure the power consumption. It was working correctly, but after a software upgrade to 6.3.60 it stopped working. I removed it and I realize the new version hasn't any menu to add meter adapter.
I can add a repeaters/lights or smart plug, but no option for power meter.
Is there any other option to add my qubino power meter to toon 1?
Thanks
Pochoto2
Re: Powermeter option unavailable Toon1
Post by Pochoto2 »
Hi again,
Here you have the available options in TOON:
TOON MENU
TOON SETTING
No option to add external hardware (except repeaters)
TOON CONTROL PLANE
Here we can only add smart plugs or lamps
It seems my toon lost the menu to add external energymeter
But i can see the energymeter is connected to TOON through the web browser (192.168.1.31 is my TOON Ip)
http://192.168.1.31/hdrv_zwave?action=getDevices.json
And i get:
"dev_10":
{"uuid": "3622b658-b5e2-4c14-bff2-296fc58bdaa7",
"name": "ZMNHTD1", "internalAddress": "10",
"type": "ZMNHTD1",
"supportsCrc": "1",
"ccList": "5e 27 32 56 70 86 72 73 85 8e 59 5a 7a",
"supportedCC": "5e 27 32 56 70 86 72 73 85 8e 59 5a 7a",
"nodeFlags": [],
"IsConnected": "1",
"HealthValue": "10"
"DeviceName": "ZMNHTD1",
"CurrentElectricityFlow": "2274.40" --> I've confirmed this consumption changes when i turn on the heater
"CurrentElectricityQuantity": "11587400.00",
"CurrentVoltage": "242.90",
"CurrentCurrent": "9.38"
"TargetStatus": "0"}}
I would like to show that information in TOON screen as it was in the pass, here an example:
Regards.
have never seen this before.
Does the xml file /qmf/config/config_happ_scsync.xml look alright on Toon?
Or try to run the script "update-rooted.sh -f"
Otherwise don't have a clue
Pochoto2
Post by Pochoto2 »
Thanks for the answer Toonz
Actually the option was removed in the last oficial SW upgrade.
This is the content of the file /qmf/config/config_happ_scsync.xml. Not sure whether it is right or not:
 <Config packageRevision="468">
  <sysConfig>
   <locale>es_ES</locale>
   <timezone>Europe/Madrid</timezone>
   <currency>EUR</currency></sysConfig>
    <device>
     <serial_number>17-34-015-111</serial_number>
     <device_type>Display</device_type>
     <device_model>6599-1701-1300</device_model>
     <hardware_version>6599-1701-1300</hardware_version>
     <manufacturer>Prodrive</manufacturer>
     <devicePackage>hcb_config</devicePackage>
     <package>happ_scsync</package>
     <uuid>7f6f5741-5eb5-4791-a7a1-86de2c075607</uuid>
     <type>deviceInfo</type>
     <name>deviceInfo</name>
     <internalAddress>hcb_config</internalAddress>
     <visibility>1</visibility></device>
    <device>
     <serial_number>1729-AA-1111</serial_number>
     <device_type>BoilerAdapter</device_type>
     <device_model>3000-0000-15-00</device_model>
     <hardware_version>3000-0000-15-00</hardware_version>
     <devicePackage>happ_thermstat</devicePackage>
     <uuid>14f82280-7add-4b63-9a0e-7e6d3ca10c62</uuid>
     <internalAddress>1729-AA-1165</internalAddress>
    <device>
     <uuid>efcea447-183a-42c0-8a69-6ccb903c3d98</uuid>
     <type>agreementDetail</type>
     <internalAddress>agreementDetail</internalAddress>
     <visibility>0</visibility><StartDate>1511740800</StartDate><EndDate>-1</EndDate><Status>IN_SUPPLY</Status><ProductVariant>Toon</ProductVariant><activated>1</activated><wizardDone>1</wizardDone><ElectricityDisplay>1</ElectricityDisplay><GasDisplay>1</GasDisplay><HeatDisplay>0</HeatDisplay><SmartHeatDisplayBasic>0</SmartHeatDisplayBasic><SmartHeatDisplayFull>0</SmartHeatDisplayFull><SolarDisplay>0</SolarDisplay><SolarActivated>0</SolarActivated><OtherProviderElec>0</OtherProviderElec><OtherProviderGas>0</OtherProviderGas><SME>0</SME><HeatWinner>0</HeatWinner><mobileAccess>0</mobileAccess><supportEnabled>0</supportEnabled><supportEnabledStart>0</supportEnabledStart><researchEnabled>0</researchEnabled><doSolarWhatsnew>0</doSolarWhatsnew><latestWhatsnewVersion>qt-gui - 1.7726-ves-NXTP-master</latestWhatsnewVersion><statusUsageFirstUse>0</statusUsageFirstUse><priceCapFirstUse>1</priceCapFirstUse><scStatusFlags>4</scStatusFlags><commissionState>4</commissionState><features></features><featureInputs></featureInputs></device>
    <device>
     <serial_number>17100011</serial_number>
     <device_type>DinRailModule1Phase</device_type>
     <device_model>ZMNHTD1 H1S6P1</device_model>
     <hardware_version>ZMNHTD1 H1S6P1</hardware_version>
     <manufacturer>Qubino</manufacturer>
     <devicePackage>hdrv_p1</devicePackage>
     <devUuid>3622b658-b5e2-4c14-bff2-296fc58bdaa7</devUuid>
     <uuid>c9408f6e-e68f-4ca9-aa15-7a6b9657696f</uuid>
     <internalAddress>17100084</internalAddress>
     <visibility>1</visibility></device></Config>
If i am not mistaken, the last device_type=DinRailModule1Phase (manufacturer=Qubino) is the power meter. It seems everything is OK and synch, because i can see the consumption though the web browser but i have no options to add an icon or something to see that information in TOON screen.
BR
Pochoto2
Post by Pochoto2 »
I've modified the file /qmf/qml/config/TenantSettings.json setting "featMeterModuleSupportEnabled": true, and now i can see the EnergyMeter in the menu:
Once configured it, setting it is a powermeter and it is analog, now it is showed as correctly synch:
But i can't add the tile to the homescreen because it does not appear when i click on "add tile"
I've check the path /HCBv2/qml/apps/homescreen, and it is empty.
I run also the firmware upgrade (sh /root/update-rooted.sh -f):
qba-900-XXXX:~# sh /root/update-rooted.sh -f
Version: 4.81  - TheHogNL - 07-08-2024
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 6.3.60.
touch: /mnt/persist/udhcpc-skip-prepend-google-pub-dns: No such file or directory
EDITING: disabling Eneco subscription feature apps to free up memory on this toon 1
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
Finished fixing files!
Interesting the line "EDITING: Activating Toon, enabling ElectricityDisplay and GasDisplay"
I restarted the GUI and the happsync, but same result, app tile missing.
killall happ_scsync
killall qt-gui
I read in some threads about this file: /HCBv2/qml/qb/base/Globals.qml (but my folder /HCBv2/qml/qb is empty, maybe it is a old file from previous TOON firmwares).
Don't know what to do now...Any clue?
Thanks!!
Pochoto2
Post by Pochoto2 »
Good News!! I could fix the issue!
I saw there were different tenant files based on the provider:
/qmf/tenants/eneco-nl
/qmf/tenants/engie-be
/qmf/tenants/qutility
/qmf/tenants/thuega-de
/qmf/tenants/viesgo-es
As my TOON comes from Viesgo, i compared Viesgo's TenantSettings.json vs Eneco-nl's one, and i identified the parameter to show the tiles is "appGraphsEnabled": true.
So right now my /qmf/qml/config/TenantSettings.json is:
	"appWeather": "",
	"appGraphTileLowestUsage": true,
	"i18nLocales": [
		"en_GB",
		"es_ES"
	"enabledHeatingSourceConfiguration": true,
	"enabledGasMeterConfiguration": false,
	"appEMetersSettingsAdvancedDisabled": false,
	"appSystemSettingsFactoryResetDisabled": true,
	"appControlPanelSmartplugHardRemoveDisabled": false,
	"appControlPanelPinProtectRemoveBridge": false,
	"appControlPanelLampRenameDisabled": false,
	"appControlPanelPlugRenameDisabled": false,
	"appControlPanelHueSceneSaveDisabled": false,
	"featPinProtectNumber": "7829",
	"appSmokeDetectorSensitivityEnabled": false,
	"featSMEEnabled": false,
	"featShowEnergyMeterImages": false,
	"featHolidayOffPeakEnabled": true,
	"featDomesticHotWaterEnabled": false,
	"featHumidityEnabled": true,
	"appSolarEnabled": false,
	"appSmokeDetectorEnabled": false,
	"appHeatRecoveryEnabled": false,
	"appCustomerServiceEnabled": false,
	"appInboxEnabled": true,
	"appControlpanelEnabled": true,
	"appImageViewerEnabled": false,
	"appBoilerMonitoringEnabled": false,
	"appWeatherEnabled": false,
	"appGraphsEnabled": true,
	"appUpsellEnabled" : false,
	"appControlPanelSettings" : {
		"smartPlugUpsell" : false
	"appSettingsSettings": {
		"askForMyOpinion": false,
		"mobileAccess": false,
		"dataTransferForResearch": false,
		"wipeUserData": true,
		"hideActivation": true
	"installationWizardApps": [
		"language|true",
		"internet|true",
		"activation|true",
		"update|false",
		"emeters|false",
		"heating|true",
		"boiler|false"
	"appBenchmarkEnabled": false,
	"appBoilerMonitorEnabled": false,
	"appWhatIsNewEnabled": false,
	"appWhatIsToonEnabled": false,
	"appStatusUsageEnabled": false
I can see the power usage!! :D
The only missing part now is the gas usage. In the past it was showed the number of hours it was working
BR
Mramos1985
Post by Mramos1985 »
Great, in the evening I will try to change this file.
Thx for your help!!
Return to “Toon Hardware”
