Temperature overshoot
If you don't know where to post, post here.
Arnout2000
Post by Arnout2000 »
This week I restarted the GUI because I received a message that the trusted certificates were updated.
Today the temperature in my living room was 20 degrees despite TOON set at 19 degrees. Normally the temperature is almost quite exact.
Is there any relation between restarting the GUI and the ‘learning’ algorithm? Is is deleted when TOON is restarted?
Re: Temperature overshoot
The 'learning' is a continuous process, if it suddenly gets colder outside it takes a bit of time before Toon gets used to it, the same when it quickly gets warmer again. This data is all stored and not impacted by a gui restart
Arnout2000
Clear. Thanks!
Return to “Toon miscellaneous”
