Using OTGW for monitoring data between boiler and heatpump
Posted: Mon Feb 24, 2025 2:13 pm
Good afternoon , I'm new on the forum. I do not have all the knowledge about the opentherm gateway, hence my question
I was looking for a way to monitor the signals coming from my ATAG boiler I36ECZ towards the management system of heatpump Weheat Flint
Both devices are at this moment connected with open therm ( wired) but I have limited access to the parameters coming and going between these two devices.
Sometimes there is an fault and the heatpump stops voor a certain time, but I get no message from the error.
Weheat supplier has blocked these messages only to use for them and the intaller of the heat-pump.
So as a consumer I'm sometimes blind to find out what actually is happening.
Would the opentherm gateway be the solution for this, and will it work in my case.?
So the boiler is connected via open therm to the management system of the Weheat pump and from this management systems 2 wires are going into the house to the honnywell T6 thermostat.
I was thinking to connect the OTGW between the boiler and management system.
I was thinking of placing one working on WIFI to connect to my windows laptop wireless
Thank you in advance
