Antenna
Posted: Tue Nov 11, 2008 9:58 am
by stefxx
I am using a RFXCOM receiver/transmitter, and I have some problems with the reception of the Visonic signals. I tried to adjust the antenna's but I am unsure which antenna is responsible for which signal.
Here is a picture. It is a "LAN 2 COM 433.92MHz transmitter + X10/Oregon receiver set (87005)" with a "868.95MHz Visonic slave receiever (40079)".
Can someone identify the three different modules/antenna's? And can the Visonic antenna be extended (assuming it is one of the wire antenna's with a longer piece of wire?)
Antenna
Posted: Tue Nov 11, 2008 10:03 am
by b_weijenberg
the middle one is the receiver for Visonic.
You can try with the antenna in the upright position without placing the cover.
Do not change the antenna wire as it is tuned to 868.95.
Antenna
Posted: Tue Nov 11, 2008 10:08 am
by stefxx
Thanks for the tip!
