Page 1 of 2
Dramatic reduction of received packets
Posted: Wed Nov 26, 2008 1:19 am
I just don't know what's happening here...[:(]
Today i saw some really strange things going on. Suddenly the amount of packets received by my RFXCOM receivers dropped dramatically.
I noticed this by motion sensors not going back to 'no motion' state the way they should (that is, by receiving a packet that says so).
I looked at my logfiles and somewhere around 06:25 today, suddenly the packet-rate on both of my RFXCOM receivers dropped enormously.
When i came home after work this evening, i thought it was RFX1 (see below) that wasn't functioning anymore (based on the sensors that were not being received anymore), so i dis- and reconnected power and left home again. Now that i'm back i had some time to analyze what the **** is going on. Here some statistics:
RFX1 RFX2 Total
25-11-2008 02:00 506 534 1040 (these are normal )
25-11-2008 09:00 34 23 57
25-11-2008 23:00 130 343 473
The numbers represent the number of packets received from a RFXPulse module during 1 hour. I focused on that module since that produces a relatively constant packet-flow. And it's not on batteries, so i could rule that out right away too.
But it's not just the RFXPulse module(s), everything has dropped dramatically regarding the number of packets received...
What is going on here? What can i do? I just don't get it.... [xx(]
Posted: Wed Nov 26, 2008 1:27 am
The only explanation I can think of in your case is heavy interference!
Did you check this.
Posted: Wed Nov 26, 2008 1:41 am
Hmm, with the means i have available..., yes.
I checked if there was a switch or something else constantly sending out packets (i have had that once before); no, there isn't.
I checked the amount of parity errors on incoming packets. They were less, ofcourse. Related to the amount of packets you could say it is the same as before.
I checked the amount of unrecognized packets. They increased dramatically too, from 37 per hour, 295 per hour to even 354 per hour!
So now i think i need some kind of 'geiger-teller' for 433 MHz so i can walk through my house (and surroundings) to capture that interferer... but how?
Posted: Wed Nov 26, 2008 1:46 am
Is the rfxmeter causing problems as well, if so you can cut the antenna on one side so the range gets better (always do this).
Device you can easily move, move them closer. I had similar problems once a while back.
The devices you receive are they close or far from the receiver?
Posted: Wed Nov 26, 2008 1:57 am
Yes, the RFXMeter is received worse (see the statistics for that).
I only checked 1 RFXPulse module, the RFXMeter has 3 of them (Power, Gas, water). Distance between RFXMeter and receiver RFX1 = approx. 2 meters. No concrete walls, just wood between them. So reception should be no problem at all i'd say.
Posted: Wed Nov 26, 2008 1:48 pm
by flexer
<br />I just don't know what's happening here...[:(]
RFX1 RFX2 Total
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Digit, how do you measure and generate these statistics?
Flexer
Posted: Wed Nov 26, 2008 2:48 pm
We have our own driver and every time a certain packet comes in we can count it.
It's also very handy for checking like: if in X minutes a packet is not received then report it.
Posted: Wed Nov 26, 2008 3:52 pm
by flexer
Hi Pieter,
I understand that you have your own driver...
But which driver is it? The RFXCOM HS plugin, RFCReceiver? Or something custom made? I'm also using the RFXCOM receiver, but I'm not aware of a standard RFXCOM driver/utility that can do this.
Flexer
Posted: Wed Nov 26, 2008 4:13 pm
We are not using Homeseer.
We have our own made driver, Rfxcom comes with a VB.NET driver as well. Its possible to adjust this code with counting the different received devices (packets).
Posted: Wed Nov 26, 2008 4:44 pm
Flexer,
Pieter is right, just as Pieter i have written my own code to handle the RFXCOM Receiver & Transmitter. And then these things like counting packets are very easy to do.
Posted: Thu Nov 27, 2008 1:21 am
Small update: our garage door opener, which has 433.92 MHz remotes, has also stopped responding to those remotes..
Posted: Thu Nov 27, 2008 9:59 am
by b_weijenberg
Digit,
It is possible that the only sensor that is received OK is the one that creates the problem. If that sensor transmits rubbish between the correct packets it disturbes all other RF transmissions.
If you can't find the bad sensor you can rent me for a few hours to help you next week using the spectrum analyzer.
Bert
Posted: Thu Nov 27, 2008 2:17 pm
by Jfn
The time it started is very strange, that early in the morning.
A few possible options:
Do you live close to a construction site where for example a crane is operated using wireless control? Starting that early in the morning is not unusual for these people.
Do you live very close to a mobile-phone base station (within a few meters that is, for example in an appartment with a base station on top) These base stations are very well filtered, but 800 - 900 MHz radiation is detectable on 433 MHz when getting close to the antenna's).
Did your neighbour start using his/her wireless headphone on 433 MHz? Although I doubt it considering the time of day, who knows?
Did it stop at a certain time, or is it an intermittant problem, or is it still causing troubles?
Posted: Thu Nov 27, 2008 10:58 pm
Problem solved !! It was a MS13 motion sensor sending garbage.
This evening i decided to 'pull the plug' on everything that could send. Slowly removing the batteries from every device, closely watching the number of bad packets coming in. This was the situation when i started:
As more and more devices were taken off the air, the number went down, but not completely, untill i removed, ofcourse, the battery from the last motion sensor:
RFXMeter was received perfectly, no bad packets anymore, so after a few minutes i tried the garage door opener. It worked again. It produced 3 bad packets, nevermind... now i'm clean for over 40 minutes [8D]
Now i can start programming all the MS13 sensors again, replacing addresses of the Oregon sensors, etc. etc. but still, you could say i'm very happy now
And thanks for thinking with me!
Posted: Fri Nov 28, 2008 12:03 am
Bert was right
Did you see these packets earlier in your receiver software, guess not otherwise you solved it already.
Why the bad packages on multiple ms13 so suddenly?
