Page 1 of 2
Plugwise Source home edition v1.0 key
Posted: Fri Nov 28, 2008 5:54 pm
by Noel
I'm about to install the Plugwise Source home edition software on a test server, but the software (to activate and install) needs an internet connection.
Problem (1). The test server does not have an internet connection. So I can not activate (and install) the software.
Problem (2)? if I install the software on a test server that does have an internet connection, will I be able to install it again (and activate) on an other "production" server when done testing?
The software will be removed from the 'test' server.
Anyone here who can confirm that reinstalling and activating (again) the software on an other PC is no problem!?
Posted: Fri Nov 28, 2008 6:00 pm
by TANE
1 - About activation I'm not 100% sure..
I think you need the connection.
2- Plugwise has build in backup DB option. Backup the test server.
Install the software on the new server..
Stop the installation process when it's asking for activation.
from start menu run restore plugwise Db..
start the new server...all will work fine with the settings from your test server.
Posted: Fri Nov 28, 2008 6:22 pm
you need Internet to activate, otherwise no go!
Posted: Fri Nov 28, 2008 6:27 pm
by Snelvuur
internet to activate, thats pretty stupid.. if i just want to use my laptop, and install it somewhere to check out some data.. o well...
Posted: Fri Nov 28, 2008 6:37 pm
by TANE
After activation there is no need for Internet connection.
Posted: Fri Nov 28, 2008 7:00 pm
by Snelvuur
but you have to copy the database over, otherwise it wont work you say ;p
Posted: Fri Nov 28, 2008 11:42 pm
Can i install the Source a second time on another system and start all over again? For example when the first system crashes and you don't have a backup? What's the 'wisdom' behind using activation anyway?
Posted: Fri Nov 28, 2008 11:46 pm
by TANE
You can do that..activation is for the software connection to you name.
Posted: Sat Nov 29, 2008 12:09 am
Ok, that's fine, so no use counter on the other side cause that would be silly.
Posted: Sat Nov 29, 2008 12:13 am
by TANE
I'm sure they have more...like the USB device serial number that is connected to your key.
Posted: Sun Nov 30, 2008 9:42 am
by flexer
What do you think Chak, is only the serial number of the USB device send to Plugwise? Or also information about the number of plugs you use and how you use them?
Posted: Sun Nov 30, 2008 9:49 am
by TANE
I think they can see more.
also the serial numbers of the devices
Posted: Mon Dec 01, 2008 1:16 am
by Ruud
That's against the privacy law, and if they also can collect other useful information "Power usage". Nice items to sale to the power company. i don't like that at all.
gr Ruud
Posted: Mon Dec 01, 2008 1:37 am
Ruud you're right, when it comes to privacy, <b>i</b> want to be the one in control of what information is sent to whatever. I don't mind my name sent in registration process, but nothing more. And i sure don't like <b>guessing</b> what more is sent!
Posted: Mon Dec 01, 2008 9:29 am
by DJF3
Can't you uncheck "Allow data/statistics to be send to Plugwise" during installation of the software? I had this option during the installation of release 20081110.
Now or in the future you'll be able to login to my.plugwise.com to check your power usage.
DJ
