When does data appear in the Plugwise charts?
Posted: Fri Nov 28, 2008 9:17 pm
The charts should appear after 1 hour, did you check the date selection.
Posted: Fri Nov 28, 2008 9:25 pm
by TANE
Sometimes it will take a bit longer when the network is not stable.
in the settings menu you can force to get the date direct.
Posted: Fri Nov 28, 2008 11:55 pm
by Noel
So.. How can I force to get the data direct.
I do not see any option for this in the settings menu.
Posted: Sat Nov 29, 2008 12:06 am
by TANE
Wifi,
They have removed this option..
did you try refresh in the main menu?
or just double click a plug this will also force a update.
Posted: Sat Nov 29, 2008 12:22 am
by Noel
Refreshing does look like it's updating, but the graph is staying empty.
Double clicking the plug pops up an info display.
Posted: Sat Nov 29, 2008 12:31 am
by TANE
Your Plasma TV is using to much....
If the date info is correct...data must be updated max after few hours..
Some time it can take a bit longer the first time when the stability of the network is not okay..
Posted: Sat Nov 29, 2008 12:35 am
by Noel
It's not only the plasma TV on that plug.
Also a Kiss HD recorder, a Roku internet radio, a video transmitter and a speaker transmitter.
Posted: Sat Nov 29, 2008 10:08 am
by Noel
Okay.. I got a graph
Posted: Sat Nov 29, 2008 11:26 am
by TANE
is it now also direct updating?
Posted: Sat Nov 29, 2008 12:32 pm
by Noel
No.. Last report was from 07:00 to 08:00.
I guess that I need to keep the source program running!
Posted: Sat Nov 29, 2008 12:38 pm
by TANE
yes..
if it's not running all the time..you will get the data after the source is running for a time..
