Plugwise MsAccess Database
Is the Plugwise data available through MS Access? (so I could write some code that generates graphs based on the .MDB data?)
Yes you can but you have to figure out the data! It looks like there are some internal functions translating the data before putting it in the database.
Just noticed that after running Plugwise (w/9 circles) for about a day, the database file in "\program files\plugwise\plugwise source\db" seems to be untouched. No changes, updates, data, etc.
Is Plugwise storing usage data in this DB or not?
DJ
DJ
actual DB is in the user profiles
<grin>
I overlooked that.. Thanks!
Re: Plugwise MsAccess Database
I am trying to get this to work as well.
I want to use the accessdatabase to see how much things has been consuming past 12h,24h and past week.
Has anybody find a way to get datafrom the accessdatabase to a webpage.
On my webpage today (www.sundshult.se/wxplugwise.php) I measure total energy and what my heating (bergvärme=heat from the ground) consumes .
It would also be interesting to see charts from my plugwise units are Consuming.
visit www.sundhult.se and under "elförbrukning" I have a lot og energy measures, se also my charts on the same page, ist a link called grafer......
I think it's easier to use the build in Webserver in the Source. This provides also creating graphs, just copy the code from the example html to your website.
- Starting Member
I'm also looking for a way to extract the data towards my own software. So far the best option I've found is by tracing the Ajax calls the built in webserver is making to update its views. Its calling http://localhost: webserver port>/_graphview.pte?cmd=appliances every few seconds to retrieve a small set of HTML containing the actual values. Would be easy to write a regular expression to filter the actual data from the HTML crap that is being sent along. The developers at Plugwise clearly did not understand how Ajax is supposed to work if they send along HTML
- Starting Member
Thanks for the info Rene. Do you have some pointers to documentation or samples how this can be done? Sounds like exactly what I'm looking for. I am getting the "Not licensed for extended scripting" error when visiting the webinterface of Plugwise. Is that a problem? Any idea whats causing this?
In the www directory of your Plugwise installation there is a directory called doc and this contains a PDF describing the scripting features.
- Starting Member
Thanks Rene. Found it. For others interested in this as well, I have made the manual available for direct download at files.koenzomers.nl/Plugwise_Source_Tem ... Engine.pdf
- Starting Member
The error "Not licensed for extended scripting" prevents one from using the script extensions. Sending your Plugwise Source license key to helpdesk@plugwise.com requesting your license to be upgraded to include the script extensions will have them upgrade your license for free.
Quick question regarding the Charts.. I'm able to create nice charts with a single URL. That's the simple part.
Now I would like to create charts with custom colors but I have no idea how. Does anyone have example code of a chart with different colors (background, bars, etc).
When that works I'll document it and post it on my website.
Thank you!
DJ
Thank you!
DJ
- Starting Member
I found out that there's actually already a lot of good stuff available by default in the Plugwise webinterface that can perfectly be used to extract the data. For example:
http://localhost:8080/api/data.xml?type=appliances
Will output a perfectly fine XML file with all your devices, its status, current usage, device name, status, etc.
Turning a device on or off or setting its lock status can easily be done via:
http://localhost:8080/api/actions.html? ... tchon&id=1
In which the option can be: switchon, switchoff, lockon or lockoff and the Id represents the Id of the device in Plugwise.
The documentation about both of these can be found at http://localhost:8080/api/index.html
There's even a RSS feed to subscribe to by default. This can be found at:
http://localhost:8080/rss/example.xml
This displays the status of all devices in a nicely formatted RSS feed. The template of this RSS feed can easily be edited by customizing the file in C:\Program Files (x86)\Plugwise\Plugwise Source\www\rss\example.xml.
Awesome stuff!
Awesome stuff!
