PMIX35 with new modules
Posted: Tue Dec 02, 2008 1:55 pm
by Harlin
First, short introduction as a new member.
I started with Xanura as een early adopter about 7~6 years ago, first very basic with a few modules, RF and a CIX. Moved in winter 2005 to a new home and introduced more modules. Due to several problems the project stalled. I got some new modules (2x SAIX12, 3x DAIX12 and 2x IMX10) to replace my old ones.
About the PMIX35, got one to play around with. If I understand the manual correctly it should be possible to program modules, incircuit without pressing the 'program switch' on the module. Default modules are set to A01, tried several times but couldn't program the module without pressing the 'program switch' on the module.
If it walks like a duck, quacks like a duck, ....
Posted: Tue Dec 02, 2008 2:13 pm
by Lempens
Did you try to place the PMIX closer (same fase) to the Daix12. Are al of them installed yet. Maybe you could try to place 1, en then programm it.
Also you need to press the button serveral times in 4 secondes before the programming begins.
Posted: Tue Dec 02, 2008 4:43 pm
by Harlin
Yes I did try the same phase. Its a DUO walloutlet, left one is modified to carry an module (SIAX12) right one is regular 220, both are connected to the same 'group'.
I didn't try to turn the powerlead 180 degrees to match the 'hot' wire. (fase op fase in dutch)
Posted: Tue Dec 02, 2008 5:20 pm
by Lempens
Did you set the PMIX analayser software in program mode, en pressed serval times 1 button. You need to do this quick.
Posted: Wed Dec 03, 2008 1:17 pm
by Harlin
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Lempens</i>
<br />Did you set the PMIX analayser software in program mode, en pressed serval times 1 button. You need to do this quick.
Nope not really, what do you mean by pressing several times one button? the PMIX program button or a contact on the module? This will be an challenge, the SAIX12's are used as an AIX12 (actor without local switching possibility)
Posted: Wed Dec 03, 2008 2:15 pm
by Lempens
That's what's told in the manual so far as I can remeber, You need to make serval time (contact on the unit).
