Plugwise Homeseer Plugin
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />I found and fixed the problem causing the "Plug-in Plugwise not responding, #32 callbacks cancelled" warning. Because it is not a critical error I wait releasing a new version of the plugin so I can include more bug fixes.
Great thanks...
Great thanks...
Ik zie waarschijnlijk hier iets over het hoofd. Ik kan het niet terugvinden hier.
Kunnen events getriggerd worden bij het wijzigen van wattage door een plug? Ik heb een event aangemaakt waarbij de tv uit moet als de value in range is van 0..80. Het event wordt alleen niet uitgevoerd. Terwijl ik op de status pagina wel de waarde van 92 Watt naar 0 zie gaan. Of kan de plugin nog geen events veroorzaken en moet ik de values pollen?
The devicevalue represents the actual usage of the connected devices. This means you can trigger on a change of the device value.
Mmmm, i see i wrote the post in dutch. Must be the time i wrote it. It does work but not with "in the range" :S
when using the option in the range
correct Homeseer formula is three dots between the range numbers.
briliant. you just can enter garbage and it will accept it. Good error checking. Thanks chak. I'll keep that in mind.
How many people are working with this plug in?
What is the purpose of the question?
Hi Rene
Just installed your HS-plugin. (source is also running )
After enable and configure the plugin I see nothing in the charts (yes i installed visifire, I see an emty chart) HS pops-up the following error:
What is it that i'm missing ?
Thanks
Wil
Even the genious ask questions.
Thanks
Wil
Wil,
The problem causing the Warning has already been fixed in a still to be released version but is not causing the errors. Could you query http://localhost:80/statistics.xml in a browser and post the output?
I use it and it's one of my populair plug-ins !!!!
Reinder you can better ask the question to Rene..he can tell you about how many downloads.
I think all the Homeseer users who also have Plugwise.
I use it too. It's a very usefull plugin! I agree with Chak, I think everybody who's using HS and Plugwise is (otherwise should be) using it.
69 downloads of version 0.3 sofar. However, I did not check on unique downloaders.
<br />Wil,
Rene,
The output is just the status overview from HS. There is nothing new to that.The plugwise however are not listed in this view.
<br />Wil,
Rene,
