cm11
Posted: Fri Dec 12, 2008 5:00 pm
by Ruud
I have a spare cm11, Can i make that at use as a control device? Is there software for "logging" or something els?
gr Ruud
cm11
Posted: Fri Dec 12, 2008 6:27 pm
by Snelvuur
i think you can use more then 1 cm11 on homeseer for instance, but if its wise.. i dont know..
cm11
Posted: Fri Dec 12, 2008 8:02 pm
by tja
Yes, you can use 2 CM11 units simultaneously.
I use it all around 1 year
One CM11 is connected to Home Seer
One CM11 is connected to Heyu (Linux)
cm11
Posted: Fri Dec 12, 2008 8:15 pm
by Rene
Connecting more than one CM11 to Homeseer is not possible and does not make sense. The CM11 itself is able to receive X10 signals from and send X10 signal on the powerline. It depends on the software you are using what you will be able to do with it.
cm11
Posted: Sat Dec 13, 2008 12:30 am
Agree, wise as Tja is doing, not wise when on the same program
