FKX40 phasecoupler
Posted: Fri Dec 19, 2008 4:08 pm
Hi all
I just installed the FKX40 and since then it is almost impossible to dim/brighten the lamp modules. It seems that each command it receives is sent at least 4 times across the same phase resulting in an uncontrollable dim or brighten action. I know it is a repeater as well but this could (to my opinion) not be the normal behaviour. Unfortunatly I don't own a PMIX35 (yet) to reprogramm it (switch of the repeater functionality)
Does anyone have the same experience? or a solution to this
Cheers
Jeff
Cheers
Jeff
