Page 1 of 3
door chime call mobile phone
Posted: Mon Dec 22, 2008 4:42 pm
by andywee
here's a situation. most of the time my wife and I are not at home. I am hoping to create a door chime that actually calls my cellphone via 3G with video. or at least a 2G phone call. anyone have any idea how to get it done?
Posted: Mon Dec 22, 2008 4:53 pm
by MindBender
You can do this using the Siemens Gigaset HC450 DECT door intercom. Together with an IP enabled DECT base station you can forward door calls to your cell phone and pretend that you're home, but too busy to answer the door when somebody rings your bell.
Posted: Tue Dec 23, 2008 6:28 am
by andywee
then wouldn't my visonic panel have a problem? cuz the phoneline is digital.
Posted: Tue Dec 23, 2008 6:31 am
by andywee
oh my bad. DECT is the phone type.. not analog/digital phone lines.
so i need to get a intercom AND the cordless. hmmm.
i dont have a phone in the house. everything is via mobile at the moment.
Posted: Tue Dec 23, 2008 8:46 am
by Dowser
Well, you only need a DECT VoIP base-station, not a phoneline. (And a SIP account to communicate with your mobile)
//Markus
Posted: Tue Dec 23, 2008 9:52 am
by MindBender
As dowser said: You just need a DECT base station, either a VoIP, an ISDN or an analog version. Usually a combination including a hand set is cheaper:
Other versions are available starting already at <100 Euro
The read die-hards here have an Asterisk (of a SIP-X) server to handle all IP telephony. This server can forward door calls to your cell phone number, but I'm sure it's possible without Asterisk as well.
Posted: Tue Dec 23, 2008 11:37 am
by drmacchi
Interesting! but how do you connect (i mean wires) the doorbell to the base station?
Posted: Tue Dec 23, 2008 12:31 pm
by Dowser
You don't.
They connect through DECT as any other handset.
//Markus
Posted: Tue Dec 23, 2008 1:16 pm
by drmacchi
Sorry i don't understand! Any doorbell is triggered by an impulse (finger push) running along cables, so how could you connect a standard doorbell (without phone options) to a dect base station, that i think, has a phone plug to be triggered? thanks.
Posted: Tue Dec 23, 2008 1:31 pm
by Dowser
A standard door-bell without any phone options is just a switch.
A switch is just a passive trigger and needs to be connected to something if it should affect a phone, corded or cordless.
Can you describe what you would like it to do, when connected to the DECT base station?
//Markus
Posted: Tue Dec 23, 2008 1:41 pm
by Snelvuur
Siemens Gigaset HC450 look that one up for more details..
Posted: Tue Dec 23, 2008 3:43 pm
by drmacchi
In fact my doorbell is a standard one, passive switch to make play a bell. this should be connected to a voip line and send the voice of who is ringing the doorbell to a predefined phone (cel****ar) number. too difficult to realize?
Posted: Tue Dec 23, 2008 3:48 pm
by Snelvuur
drmacchi: its not that easy, you need a mic, a speaker, you need some sort of voip behind it.. and it needs to dial out when you press the buzzer, and you dont want it to call you when your home perhaps. Also you want to open the door with the phone for instance which requires some sort of numeric response from the phone (like asterisk can) and that all.. thats not easy.
Gigaset HC450 is just a box you place at the door, and it hooks up to your voip sollution (which can be asterisk) and then other phones hook up to it aswell.. and then your done, it can also open the door and stuff.
Posted: Tue Dec 23, 2008 3:58 pm
by Dowser
drmacchi:
If you really like your current doorbell, you can keep that button and connect it to some homebrewed solution. As snelvuur mentions, you will need a microphone, a speaker, something to attach it to a computer (or a dialer) and a SIP account.
The simple solution is to get a Simens Gigaset HC450, a VoIP base-station and just follow the step-by-step directions.
My suggestion is:
If you need to ask on a forum how to connect your doorbell to a mobile phone, go with the Gigaset solution.
An Aserisk solution is powerfull, but has a steep learning curve and is overkill just for a doorphone.
//Markus
Posted: Tue Dec 23, 2008 4:08 pm
by drmacchi
Thanks both, that's all clear now.
Lorenzo
