Electricity meter with S0 output DIN 43864
Posted: Sat Jan 20, 2007 3:38 pm
by Willem4ever
Guys,
I have a electricity meter with a S0 output following DIN 43864 specifications. I can only find maximum ratings for this standard, i.e. 27 VDC, 27 mA. I believe this is a normal OC (opto-coupler) output, so in theory i should be able to connect it directly to a counter like the TAI8585, or do I need additional components ?
Thanks, Willem.
Posted: Sun Jan 21, 2007 2:16 am
Willem,
AFAIK the TAI8586 has opto-couplers, the TAI8585 doesn't...
http://www.aagelectronica.com/pdf%20doc ... ounter.pdf
http://www.aagelectronica.com/aag/index ... lang=en-us
What i do know for sure, is that i once connected a KWh meter directly to a counter from hobbyboards.com based on a DS2423, just like the TAI858* is. I can't recall exactly how i connected everything, but i *do* recall i didn't need any additional components or power source.
The hobbyboards kit i used does not have opto-couplers 'in front' of the DS2423. And the TAI8585 is much like hobbyboards kit.
Further more, i know i once read a topic on the homeseer forum a long time ago about this subject, and i had a quick look for you to see if i could find it again, and here it is:
http://board.homeseer.com/showthread.ph ... hlight=kwh
See page 2, that's where the TAI8586 is discussed.
HTH,
Robert.
Posted: Sun Jan 21, 2007 8:14 pm
by Willem4ever
Hi Digit,
I'm using the the GP1 counter from Embedded Data Systems. I decided to take my changes and hooked it all up today, and yes it is counting !!! While awaiting the Eltako meter, i bought an El Cheapo on eBay (for testing purposes) and it seems to work fine. Having the stuff on the floor (below my desk) makes it all a bit easier to test the setup before it all goes in the wiring closet.
Willem.
Some output ....
Sun Jan 21 18:40:00 2007 5256
Sun Jan 21 18:41:00 2007 5258
Sun Jan 21 18:42:00 2007 5260
Sun Jan 21 18:43:00 2007 5263
Sun Jan 21 18:44:00 2007 5267
Sun Jan 21 18:45:00 2007 5269
Sun Jan 21 18:46:00 2007 5269
Sun Jan 21 18:47:00 2007 5270
