delay time
Posted: Thu Jan 15, 2009 12:50 am
by Ruud
What is a average delay you fellows use on a ms13.
I have set it to a minute, but i the morning i missing alway's the dark/light signal in homeseer. Please advice
Gr Ruud
delay time
Posted: Thu Jan 15, 2009 1:02 am
The dark/light has nothing to do with delay time setting.
This is what the manual says about delay time: "the length of time that the lamp will remain illuminated after the last motion has been detected". So i don't see how this could influence dark/light.
delay time
Posted: Thu Jan 15, 2009 1:03 am
by Antoon
I also use 1 minute for all of my MS13.
That you are missing the dark/light signal has nothing to do with this time.
Maybe the MS13 is to far away from your receiver or the batterie is bad.
With the cold temperature of the last weeks maybe the MS13 is not working properly because of a poor batterie.
I replaced my batteries also a couple of days ago.
- Antoon
delay time
Posted: Thu Jan 15, 2009 1:38 am
by Ruud
Sorry i ment, when i wake up "movement" and then i put on the light.( take's a minute to do that)
I think that the movement signal kills the dark/light signal
I know that the delay is for the movement and not for light/dark
Gr Ruud
P.s movement signal is always detected (rfxcom) and the battery are new
delay time
Posted: Thu Jan 15, 2009 8:45 am
by Mdamen
Dark/light is seperate from movement on a different x10 code. Which is set unitcode + 1. Are you sure you have it enabled?
Maarten Damen
www.maartendamen.com
delay time
Posted: Fri Jan 16, 2009 1:23 am
Ruud,
You know the sensor has 4 operating modes:
- motion detector is on during the day, light/dark sensor off.
- motion detector is off during the day, light/dark sensor off.
- motion detector is on during the day, light/dark sensor on.
- motion detector is off during the day, light/dark sensor on.
Maybe the wrong mode is causing you the troubles?
