Powerlink for Visonic
Moderators: Rene, Willem4ever
www.Waakzaamwonen.nl has the Powerlink internet module for the Visonic Plus and Pro (first in the Ntherlands)
Check the site: http://www.waakzaamwonen.nl/catalog/pro ... ermax-plus
http://www.waakzaamwonen.nl/catalog/pdf/powerlink.pdf
Leuk maar de meeste functies zal iedereen al hebben. 200 euro om remote te kunnen schakelen vind ik best veel. Misschien komt er nog eens een simpele koppeling met HS? wel leuk dat er nog zo door ontwikkeleld wordt.
ziet er mooi uit....maar krijg het gevoel dat je een abo nodig hebt om te kunnen gebruiken.
in PDF zie je een url wat via visonic loopt.
It's working with a service center (secure website) Will probably be available Q2 2009.
I'm not sure if you can work around this and connect the powermax directly?
I was told that the English version available through Waakzaam Wonen uses free access offered by the Visonic website in Israel. It is an external unit (so no plug-in internal unit for the Pro).
The Dutch version (should be available Q2) will use a paid subscription.
- Snelvuur
paid subscription, when will they get it that nobody wants that..
Is it working with normal IPcam's , or only the visonic cam's
gr Ruud
gr Ruud
- Willem4ever
- Global Moderator
Anyone hands-on experience with the Powerlink module. It seems you can have direct internal access (when browsing thru the manual)
The Powerlink is a non-adjustable webserver. After you login (SSL protected) you can see the status of your Powermax, see the images of your webcams (if connected) and arm/disarm your Powermax.
<font color="blue"><i>Stap 1: een Powermax Pro installatie ...</i></font id="blue">
Is only supports the Visonic IP-cams CAM1000 en CAM2000(+WL).
The PowerLink should be able send out emails, sms and mms (email/mms with a camera snapshot in it), but so far I did not manage to get that working (where can I set the SMTP to use to send email?).
Cyril
Cyril
- Starting Member
Hi, i am very interested in the powerlink, can any one post some experiences with the device.
My specific question's are:
The website it self, is it html / javascript ? (can u use a direct link to enable the alarm (that way you can intergrate it in domotica software))
does it have a subscription, sms services usually cost money how does that work?
i read something about http://powerlink.visonic.com/deviceId < how does that work..
