Doing something wrong - trying to change base add
laserchris
Post by laserchris »
hi there i have three temperature sensors which are all on the default base address... this means that when I try to add them to homeseer i can only see one of them
i tried to follow the instructions to change the address but i must be missing something
i get this repsonse
20FC0C841B RFXsensor[64524]T RFXSensor addr:FC0C ID:64524 Error: No end of read signal received from 1-Wire device bits=32
and then when i reset again it goes back to the 240 address
can anyone help
Chris
b_weijenberg
Post by b_weijenberg »
laserchris
yeah i think i have tried that .. but i must be doing something wrong... does the output above look wrong?
laserchris
Do u have a picture of how to use the 3mm pin in the jack connector?
I was using the 3.5mm jack which I now realize is wrong
Chris
b_weijenberg
use a 3.5 or 3mm drill.
The metal pin must create a short circuit on the first contact in the jack input and the ground of this input.
