Homeseer is working proparly at the moment and my Visonic sensors are visible in HS (Thank you Maarten).
Next move is to arm and disarm my Powermax. Can someone with the same equipment guide me during this proces?
You can add me at waypoint99@msn.com
Visonic Powermax + configuration in HS
Moderators: Rene, Willem4ever
That would be very nice,
I'm also intressed in "remote" arm and disarm a visonic system.
Could that trough RS232 of X10 ? Would somebody know?? en how? or know the commands...?
You can modify the keyfob by adding two wires and connect this to the UM7206
UM7206 can be controlled via HA
I'm going to do that only for Arm command.
Be sure that you place the keyfob somewhere that the intruders can't find it in few seconds.
Its only for the commands to arm and disarm my PM+. Correct me if I'm wrong but would a XM10 interface to communicate between HS and my Visonic be sufficient also?
ARM command is okay..you can do that from HS when you modify the Keyfob.
Disarm will also work but a bit risky
The only method to give the Powermax commands without using the console or a keyfob is by using Powerlink. It would be interesting to known how the Powerlink module interfaces with the Powermax so we could use this type of interface to issue commands from within Homeseer.
