De Plugin begint langzmerhand wat meer 'inhoud' te krijgen. In het begin zat ik als HS-dummy te worstelen waar ik toch met al die info naar toe moest; 2 telefoonnummers, een tijd, een gespreksduur, inkomend/uitgaand, waar laat je het allemaal...
Maar ik denk dat ik daar wel een leuke oplossing voor heb gevonden; de HS-gebruiker bepaalt zelf maar hoe de Devicestring er uit komt te zien door het opnemen van zgn. specifiers in het configureerbare DeviceStringFormat. Leuker kunnen we het niet maken...
Zie ook http://blog.hekkers.net/2009/03/10/frit ... ogressing/
Fritz!Box Plugin
Moderator: RdP
- Starting Member
Fritz!Box Plugin
is there a newer plugin?
i've installed to the plugin but with incoming calls i get HS crashes.
The system writes that it has problems to write to the database and will get a wrong index
Fritz!Box Plugin
Hi mikschreiber,
Did you check the topic on HS forum lately? I posted there when i heard of your problems. Please check there and if this does not resolve your problem, please report back (preferably on this forum, since i visit HS forum maybe 4 times a year)
- Starting Member
Fritz!Box Plugin
Just now i do not get this crashes but still have the problem that incoming calls are not displayed.
ok - if i call from one line to an other line (my own lines) then the outgoing and incoming call is displayed.
*solved: ok - after restart of HS its working.
by the way do you know this prog: http://www.jfritz.org/wiki/JFritz ..perhaps there could be done a combination. The guy who is doing this project is one of my friends and he knows all details about the different firmware versions and fritz boxes But lets stay in touch, perhaps there is a possibility to do a reveres search in public dirs like it is done in jFritz
Fritz!Box Plugin
JFritz is indeed a nice application.
Combining of some functions will be great.
Lot of the functions are already on the request list of Robert
Fritz!Box Plugin
Hi mikschreiber,
Good to hear problem are gone now.
I know about jFritz, i've taken a look at it in the beginning when i got my own Fritz!Box 7170. I integrated call monitoring in my own, homemade HA system and was triggered by Chak to make a HomeSeer plugin for the Fritz!Box. There's still a lot of things that can be added to the Plugin, so yes i think it's a good idea to stay in touch [:)]
- Starting Member
Fritz!Box Plugin
Hi Robert,
i am too new here to ..
and not allowed do send a private msg.
can you send me your email as privat msg?
i do not know if you speak german, but a lot of informations regarding the FBox is here: http://www.ip-phone-forum.de/showthread.php?t=194449
and the guy who is doing the jFritz is skyteddy - i've just now written a mail to Rainer regarding your plugin
Fritz!Box Plugin
Done.
