HCB software and ZAX
Posted: Sun Feb 15, 2009 3:55 pm
by Luc21
Hi there,
I've encountered a strange problem after updating my HCB with the latest firmware. I cannot create a macro with my ZAX module anymore. All other modules seem to work but when I want to create an action in the macro I can't save it. Below in the window it says that Explorer has an error on the page (Object demanded). Everything else works, I've tried firefox, also doesn't work. Only all my ZAX modules have this problem, has anybody else experienced this as well?
Thanks
Luc
Posted: Sun Feb 15, 2009 8:02 pm
by Henk
Luc,
I have no problem at all programming ZAX modules in the HCB .. i'm using the HCB version 1.4.18-993.
Do you have the same version ?? if not i can send you a copy ...
Henk
Posted: Sun Feb 15, 2009 8:25 pm
by Luc21
Hi Henk,
Thanks for your reply, I have 1.4.15-983 which is the latest free download I believe. You would do me a huge favour to mail the latest one.
Best regards
Luc
Posted: Tue Feb 17, 2009 9:01 am
by Luc21
Thanks to Henk the problem is solved, apparently there are some bugs in the 1.4.15-983 firmware, in the newer one these bugs are solved. (Hopefully it will be put on the xanura website soon)
Posted: Fri Feb 20, 2009 12:56 am
by michelr
Hi Henk,
Can you send me thenew software also.... i think i have a problem with the 1.4.15.983 to....no module i get adressed..
Thnx..
Posted: Tue Mar 10, 2009 9:14 pm
by mar99
hey Henk,
would you send me also the new software. can we download them by or self? i have also the 1.4.15.983 with many bugs :(...
thnx alot
Posted: Wed Apr 01, 2009 12:29 am
by Donald
I just downloaded & installed the latest firmware from Xanura 1.4.18-993 (http://www.xanurahome.nl/Handigetools/t ... fault.aspx).
With my prior firmware version (1.4.14-940), it showed the actual dim percentage of an actor on the status page. This new version does not show the actual dim percentage.
Are others also facing this problem? Is there something I can do to fix this?
Donald
