Plugwise Source Server
Hello everybody
I use some perl scripts in order to get data from the Source Web Server. I noticed sometimes in the Plugwise Sttings/Program that the webserver is Stopped (it shouldn't), I have to restart it manually. Did you notice this kind of irregular behaviour ? The source software is on a dedicated Windows machine.
Thank you and regards, Radu
RC
RC
I'm running the webinterface for long time 24h a day..never had this problem.
You can export the settings of the plugwise and tray to reinstalling on another machine.
Chak,
are you running the source or the seperate webserver?
I'm running all my domotica software on the same machine (Asus EEE box)
Homeseer
Plugwise
Itunes
Irtrans
Hstouch client
Homeseer
Plugwise
Itunes
Irtrans
Hstouch client
I ment are you running the source plugwise software or the special webserver plugwise program
I'm running the original client software
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>I'm running the webinterface for long time 24h a day..never had this problem.</i><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I thought you meant the webinterface (PlugwiseServer.exe) version
Radu uses the Source software (not the server itself) which in turn starts automatically the webserver. I chose that because otherwise I canot start the server itself at boottime. I wonder if the server itself has a logfile or something like that
Radu
RC
Radu
RC
PlugwiseServer.exe is only the webserver, you can poll this webserver and get the same information as with the source, the source has also a GUI for graphs and direct info.
It's also very lean and mean regarding taking resources from your computer (less memory ect).
I heard that the dedicated PlugwiseServer.exe have some little bugs.
I hope they fix this in the next update.
I'm looking into the webserver features. As far as i can see it is only possible to request the current poweruasage and /or the total power usage. In the source application it is possible to view historical information per appliance / group etc. Does anybody know if it is also possible to request this "historical" information from the webserver application?
It's not possible. This is one of the requests I dropped at Plugwise when I visited them some weeks ago.
Thanks Rene. I'll try to find a workaround.
Has someone of the beta testers already tried the separated plugwiseserver.exe ??
