installation schema
Posted: Tue Mar 03, 2009 5:39 pm
by Alexander
Gents,
As i'm installing the stuff i don't understand why eaton equipted the modules only with one fase connection. Look at the SAIX12/DAIX12 module. You would still need a switch to manually switch the light, but you'll need a breakout to add extra fase wires. Instead the modules are equipted with 2 null connection eventhough you would only use one (for the module itself). Why not one null connection and two fase connections?
example wiring : http://www.domoticaforum.eu/topic.asp?TOPIC_ID=813
Or are there people around here that switch those null and fase wires?
