Installed gambas and domiga, en got this error at 60% starting
Error: Unkown field: debugdevices -1 Main.GetSetting.464
Program aborted
any idea what goes wrong?
Error statring domotiga
Moderator: RDNZL
- Snelvuur
after you loaded the initial sql, did you also install the "upgrade" sql's ? you need those too..
now did try upgrade
mysql -u root -p <01158to01160.sql
Enter password:
ERROR 1060 (42S21) at line 129: Duplicate column name 'value3'
Enter password:
- RDNZL
you need to load all upgrade sql's except the one you tried [:o)]...
That one is already in domotiga.sql.
But it doesn't hurt you only get the error message.
See also here http://www.domoticaforum.eu/topic.asp?TOPIC_ID=2410
In the next version these will all be cleaned up.
Even thinking about automating this process, thats why I have changed the names.
ron.
ron.
Hi Ron,
That's working.
Another question, I can select DS18S20, but not the one wire adapter, ds9097. I think it's easy to integrate digitemp for it???
http://martybugs.net/electronics/tempse ... rdware.cgi
http://martybugs.net/electronics/tempse ... ftware.cgi
That's working.
- RDNZL
Yes that should be easy to add, I must have such a 1-wire adapter somewhere, have to try to find it and let you know.
Maybe in the meantime you can install digitemp like described on martybugs site let it run for some time and give me some grabbed output and config file to test with per PM?
Ron.
Ron.
