From what I have heard/think the following subject from the list are solved:
Summary (detailed in posts below):
* Plugwise Ethernet controller instead of the USB dongle - ALL -> NO, not planned
* Option to run the software as a service - Wifi -> NO not yet but planned for the future
* Remote web application with full functions as in the client - Chak -> NO not yet but planned for the future
* Explanation of the fields in the MSAccess MDB database - DJF3-2 -> NO, not planned
* Complete the small webserver version PlugwiseServer.exe, is
not running good now! - Chak/Bwired -> YES, must be solved but bugs found.
* Homeseer plugin - Rualblas/ALL -> Yes, by Rene Klootwijk
* 64 bits support - Snelvuur -> Yes, must be solved but not tested
* LINUX Support - Snelvuur/ALL -> No, but working on that (Mono).
* Fill-in registrationkey without
Internet connection is not clear - Snelvuur -> Yes, separated registration possible.
* Fill in custom "Application types" - Wifi -> No, but list updated.
* On Off button on the circles" - All (seperate On Off switch is planned) -> No, with separate switch
* Graphs and Data updated more frequently" - de.lesse -> Yes, solved.
* Publication of the protocol between source and stick - ALL -> No, please use webserver.
* Dimm options - wwolkers -> No, not planned.
* Less flimsy safety ground pins - Lennart -> Yes solved. Metal construction of grounding change
* Automatic restoration of on/off state after a power failure - Lennart -> No, hardware change necessary (relais).
* UK Plugs - Wifi -> No, but planned second half 2009!
as in between solution already a "build in"
PCB product deliverable with crown stone
connection (de Stealth).
* Readings are dropping to 0 while device is in fully use on the circle -> Yes, solved!
see (severe bug plugwise) topic
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=2383
