Do I need 3 RFXPwr's to measured all the phases, or can I run all 3 (brown) wires thrue the one clamp-on?
RFXPwr and 3 phase's
I did ask the same question 2 weeks ago:
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=2584
You also need to plug each power supply into the righ phase (which implied that I had to create an extra 230V outlet in my switchboard....)
Thanks for the info. I should have used the search option better (it's really bad on this forum)
Anyway. It looks like I need to get two more RFXPwr's.
The extra 230V outlets for each phase is going to be a problem (not much room to work with here)
try via google
<item to find> site:domoticaforum.eu
