Difference RFXmitter and the "normal" Transmitter?
Posted: Fri May 08, 2009 11:18 am
by ravensteijn
maybe this question is answered already but what is het difference between:
-RFXmitter and the "normal" transmitter?
the only thing i see is no HomeEasy EU support.
why does the rfxmitter only supports Homeseer plugin and no other programs? the normal transmitter does support other programs. am i correct?
thanks
Posted: Fri May 08, 2009 11:24 am
by b_weijenberg
The RFXmitter supports in addition to the standard transmitter the following protocols:
HomeEasy EU,
Ikea Koppla,
Flamingo,
ATI Remote,
Robocam/Ninja.
The RFXmitter is supported by the Homeseer RFXCOM plugin and xPL.
Posted: Fri May 08, 2009 11:38 am
by ravensteijn
thank you for the quick answer.
so if i want to use an other program then homeseer i need the standard transmitter and if i want to use homeseer i need the rfxmitter?
the standard transmitter can't communicate with homeseer plugin?
So i can't switch software in time if i choose one of these transmitters?
i'm sorry for all these questions but it;s not clear for me.
Posted: Fri May 08, 2009 11:41 am
by b_weijenberg
The standard transmitter can also be used by the Homeseer RFXCOM plugin.
Posted: Fri May 08, 2009 11:46 am
by Jfn
Bert,
will there be support for the RFXmitter in other software? Or is development of such software limited by an NDA? (Which rules out a language like perl that I am using).
Posted: Fri May 08, 2009 11:50 am
by b_weijenberg
RFXmitter protocols are delivered under NDA.
Other software can use the standard transmitter using the X10 protocol to control all devices.
Posted: Tue May 26, 2009 8:42 am
by eightman
How can I determine the UK or EU model for HomeEasy if I buy it online? I would like to develop it using perl/linux for UK version with the standard transmitter.
