Niet gebruikt nog met afgeplakt lenskapje etc (nwe dus)
incl voeding en visca plug voor zelf maken rs232 kabel
twee van dezelfde camera's draaien op Bwired
Gaat bijvoorbeeld perfect samen met bijvoorbeeld de axis 241Q
210 euro incl verzendkosten
Zie voor beschrijving en voorbeeld foto's (is niet de camera )
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=330
Specificatie:
Model Description:
Color PTZ Camera (fewer functions)
Model Details:
Lower cost version of the EVI-D30C by eliminating functions, omits the AT and MD, A/V out, RS-232C out, as well as other functions
Features:
High Speed, Wide Range Pan/tilter
X12 Optical Zoom, High Speed Auto-Focus Lens
6 Position Preset
RS232C Control Input Terminal
This function automatically controls the zoom lens to ensure that the size of the subject remains constant on the screen.
The EVI-D30L employs the auto exposure and advanced backlight compensation systems to ensure that the subject remains bright even in harsh backlight conditions. Because the subject position is know a comparison can be made between its brightness and that of the background and the camera subsequently adjusted to compensate for the conditions.
Video Signal: NTSC
Image Sensor: 1/3" IT Color CCD
Effective Pixels: 768 (H) x 492 (V)
H. Resolution: 460 TV lines
V. Resolution: 350 TV lines
Lens: X12 Power Zoom, ~f=5.4 to 64 mm, F1.8 to F2.7
H. Angle of View: 4.3° (tele end) to 48.8° (wide end)
V. Angle of View: 3.2° (tele end) to 37.6° (wide end)
Shortest Subject Distance: 10mm (WIDE end), 800mm (TELE end)
Min. Illumination: 7 lux (F1.
Illumination Range: 7 to 100,000 lux
Auto Exposure: Auto Iris, AGC
Shutter Speed: 1/60 to 1/10,000 sec. (VISCA™ control)
Gain: Auto/ Manual (VISCA™ Control)
White Balance: TTL Auto Tracing/ One Push Hold, Indoor Preset, Outdoor Preset (VISCA control)
S/N Ratio: more than 48dB
Pan/Tilt: Horizontal ± 100° (Max speed 80°/ sec),Vertical ± 25° (Max speed 50°/ sec)
S Video Output: 4 pin mini DIN
Control Terminal: RS232C, 8 pin mini DIN, 9600bps, Data 8 bit, Stop 1 bit
Power Requirements: DC12 to 14V
Power Consumption: 11W
Operating Temperature: 0 to 40°C
Storage Temperature: -20 to 60°C
Dimensions (W/H/D): Camera 142 x 108.9 x 159.9 mm
Weight: Camera 1200g
Te Koop Sony EVI-D30L Pan Tilt & 12x Zoom camera (verkocht)
Zijn die cams er nog?
Ja
ik heb er nog 1 als boven.
hmm... heb geloof ik wel interesse etc ... neem ff contact op via de mail etc want ik mag jou niet mailen
PM Send
