How Wisselschakeling Hotelswitch
Posted: Sun May 17, 2009 8:30 am
by Edwin
Is it possible to use the kaku built in switch with a ( wisselschakeling ). And if yes , how?
Thanks, edwin
Posted: Mon May 25, 2009 11:35 am
by bartg
Hi Edwin,
I think you mean the AWMR-210 or AWMR-230? You should be able to use it in a 'wisselschakeling'. The unit switches based on change between the connection state of the two switch wires.
Bart
Posted: Mon May 25, 2009 3:14 pm
by Snelvuur
isn't "wisselschakeling" not "hotel" switching? (only with hotel its mostly 3 switches, instead of 2)
Posted: Mon May 25, 2009 5:18 pm
by b_weijenberg
Posted: Mon May 25, 2009 5:50 pm
by Fantic
Hotelschakeling is with 2 'wissel' switches and can be extended with 1 or more cross switch when you need more switching points, these cross switches go in between the 2 lines of Bert's beautiful drawing.
Posted: Mon May 25, 2009 8:31 pm
by Edwin
Thank's for the drawing i see now that it's no problem to make it.
Thank u all for helping me ;-)
Posted: Fri Nov 06, 2009 11:52 am
by nebreg
Is this possible/allowed ?
Posted: Fri Nov 06, 2009 1:18 pm
by petermdevries
Nope...
Tried this recently, but resulted in strange behaviour and finally a defective dimmer. I replaced the switch by a "dubbele wisselschakelaar" such that the input lines are both separated and now it is working fine.
Posted: Fri Nov 06, 2009 2:28 pm
by nebreg
That's not the issue.
I already have a "dubbele wisselschakelaar", one switch for the lamp in the hall and the other lightswitch is for above the stairs
There 5 wires to this switch.
1 fase (feeds both switches)
2 black ones to the other "dubbele wisselschakelaar" in the hall
2 black ones to the switch upstarts
Sadly there is no space for 6 wires and i really want to use my original jung AS500 "dubbele wisselschakelaar" switch
Posted: Fri Nov 06, 2009 2:43 pm
by petermdevries
I run into problems after linking input lines to eachother (see drawing what caused the problem). I also tried various combinations without success.
