Laatste versie plugin
De laatste versie van de plugin is versie 0.3 (nog steeds).
This version includes some charts for total usage and the actual usage. These charts are updated automatically (10s interval for the actual usage and 5m for the total usage). I will add more charts in the near future. Because the charting functionality is not part of the plugin but implemented using asp.net scripts, it can be upgraded independent of the plugin.
Changelog for beta 0.3:
Fixes:
- Multiple devices can now be turned on or off from within one action.
- Fixed writing statistics to the database
- When Homeseer is started any state changes that occurred while Homeseer was not running are now correctly determined
- The control buttons will no longer be hidden when the manual state changes of a device are disabled. I could not get this feature stable, sometimes it worked, sometimes it did not.
New features:
- User and password for the Plugwise Source web server can now be configured
- Besides on and off the status of a device can now be offline or unknown according to the status of the device in the Plugwise Source.
- When homeseer is started the status of all devices is set to unknown. This will be updated after the first poll of the Plugwise Source web server.
- When a device is locked using the Plugwise Source directly, this is reflected in Homeseer. When a device is locked in the Plugwise Source, the lock status can no longer be configured using Homeseer.
- When the status of a device is offline or locked, the device can no longer be switched to on or off.
- New configuration options are available to use the location (room) and/or device type as specified in the Plugwise Source.
- Authentication for the Plugwise Webserver is now supported and can be configured using the plugin configuration screen.
- Available actions for Plugwise devices in events are limited to on and off.
Installation instructions:
Fresh install:
1. Download plugin from http://house.klootwijk.org/downloads/hs ... se-0.3.zip
2. Copy the following files to their target location
All files in the /html directory to <homeseer dir>/html
/data/Plugwise/plugwise.mdb to <homeseer dir>/data/Plugwise
/hspi_Plugwise.dll to <homeseer dir>
All files in the /Plugwise directory to <plugwise dir>/www (NOTE: This is the directory the Plugwise Source software is installed in)
3. Restart Homeseer
4. Enable the Plugwise plugin from the setup/interfaces screen
5. Configure the plugwise plugin
Upgrade from previous beta:
1. Stop Plugwise plugin in Homeseer
2. Select all plugwise devices in the status screen and delete them
3. Go to fresh install
How to enable the charts:
1. Download visifire components from http://www.visifire.com
2. Copy the following files to the <homeseer dir>\html\Plugwise directory:
- Visifire2.js
- SL.Visifire.Charts.xap
3. Make sure Microsoft silverlight is installed on the computer where you want to view the charts
Fixes:
New features:
Fresh install:
3. Restart Homeseer
- Visifire2.js
Great, can we make this sticky at the top?
Toppie Rene,
Is de plugin weer goed in beeld.
Kan je de buglist en wensen topic ook hier na toe halen?
Gr Ruud
Gr Ruud
@edwin2008: This topic is already sticky.
sorry, did not see that
Morgen komt mijn doos
Ik heb alles al vast geinstalleerd, inpluggen en gaan hopelijk. Rene bedankt voor al het werk, het ziet er goed uit.
Bastiaan
Bastiaan
Hoe weet je dat het er goed uit ziet als je nog geen plug hebt
Ik heb natuurlijk in alles zitten neuzen al kon ik nog niets uitlezen.
Kwam net bij het installeren we wat tegen:
Ik had bij mijn 'proberen'al een naam en wachtwoord ingegeven. Die heb ik tijdens de her installatie van de source aangepast. Daarna kreeg ik de plugin niet meer aan de praat ondanks dat ik de config alles opnieuw had ingegeven. Na even zoeken, zag ik dat het wachtwoord (onversleuteld) in de DB staan maar nog op de oude naam. Ik had zeker drie keer opnieuw het wachtwoord in gevoerd maar blijkbaar belande dat niet in de DB. Misschien even iets om te checken?
Vreemd. Als ik het hier probeer dan gaat het gewoon goed. Zal er nog eens naar kijken, want de versie die ik gebruik is al wel een aantal versies hoger dan die ik op m'n server heb staan.
Het zal ook niet zo vaak voorkomen dat iemand z'n wachtwoord aanpast
Wanneer ga je ons verblijden met de update?
Ben nu druk met een user interface te bouwen voor een touchscreen wat ik op de kop getikt heb. Dus ik doe geen toezeggingen;-) ZIjn er ernstige tekortkomingen op dit moment?
Ja veel leuker natuurlijk interface voor jezelf. Ik heb nog geen tekort komingen ontdekt. Hoogstens dat ik een knop zou willen die direkt naar de "actual page" gaat. Is dat te linken?
Heeft het nog voordelen om met de beta te werken? Dingen beter?
Knop kan je zelf toevoegen
makkelijkste manier is via link editor
plugin hier voor kan je downloaden via HS download.
Enver, ik heb de boel al draaien en links aanmaken kan ik ook
Alleen heb ik nu een knop Plugcharts waarna ik op een vervolg scherm moet kiezen voor "actual"
Omdat ik meestal Actual wil zien, zou het handig zij om een 'default' in te kunnen stellen of direkt te linken.
ik gebruik de charts niet op mijn Mac
Er is wel een versie voor de mac beschikbaar..heb het ook wel eens genstalleerd.
Voor een actuele overzicht ga ik altijd naar de status overzicht.
