Te koop DigiBUTLER Ethernet WEB-controller (Elektor)
Posted: Fri Jun 05, 2009 8:25 am
by Grab485
I will to sell DigiBUTLER Ethernet WEB-controller (Elektor)for 100 Euro
and programmer TBLCF for 50 Euro
All hardware is soldered and tested. In full working condition.
The DigiButler has DHCP enabled, thus will work in any Ethernet network.
http://www.elektor.com/magazines/2008/a ... 9032.lynkx
Posted: Fri Jun 05, 2009 9:49 am
by Lempens
whats the different with the version that Elektor sells for 37.70
other then it's being soldered and tested.
http://www.elektor.com/products/kits-mo ... 1183.lynkx
Posted: Fri Jun 05, 2009 10:08 am
by Grab485
The difference is: it has different (latest) firmware with DHCP enabled.
You can not buy it. You have to compile and burn it by yourself. Of course, sources and manuals are available.
It took 1 week for me. I am an experienced embedded electronics engineer. For normal people it is nearly impossible. Because before one should buy or make a programmer. And story begins again.
Otherwise you will stuck with pre-programmed IP address in a subnet 192.168.0.XXX with no chance if your network is for example 192.168.1.XXX. Moreover, the old firmware has a bug, when it does not connect to Ethernet with some hubs.
So the difference is as between died and alive body: the soul :)
Posted: Fri Jun 05, 2009 1:13 pm
by RDNZL
I have a digibutler in a box still to be build, thought about selling it, but I have waited for months (half year maybe?) to get it delivered because of PCB design/build errors, so I'm kinda attached to it ;-)
No idea what to build/realize with it though, any ideas anyone?
Ron
Posted: Fri Jun 05, 2009 1:23 pm
by Grab485
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RDNZL</i>
<br />I have a digibutler in a box still to be build, thought about selling it, but I have waited for months (half year maybe?) to get it delivered because of PCB design/build errors, so I'm kinda attached to it ;-)
Ron
For the first, try to use it as a remote (thousands miles) control for your kitchen light. It was designed exactly for this.
Posted: Fri Oct 30, 2009 9:01 pm
by timf1
hi Grab,
If you alwayse have a Digibutler and/or a TBLCF for sold, give me a signed!
Posted: Sat Oct 31, 2009 9:16 pm
by Grab485
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by timf1</i>
<br />hi Grab,
Yes, I am still alive [:)] and I have one Digibutler and one TBLCF for sell.
