micro lamp module with flashing problems
Forum about PLCBUS devices & software.
Moderator: Digit
Postby gjniewenhuijse » Tue Jul 28, 2009 11:18 am
I have a plcbus II R2263DE One Load Lamp modules installed. Some times the lamps gone flashing.
I installed a filter (PLCBUS 4821) and thats no solution for the flashing problems.
Anyone a solution for this?
gjniewenhuijse
Postby r_255 » Tue Jul 28, 2009 7:05 pm
No, i dont have any solution. Sorry to say tho...
Supplier told me to buy a filter, so guess thats not a option.
Can you have a look or you also got a pattern in flashing. Here it happends at whole and halve hours.
I dont have any timmer equiped stuff that could interfear at these times.
I got 3 (hallogens) 220v spots connected to each dimmer.
Hope we can sort something out!
r_255
Postby gjniewenhuijse » Thu Jul 30, 2009 11:03 am
I can't find a pattern. But most times when the light on the street goes on i think the problem is bigger (more flashes). So i think its a problem from outside my installation.
gjniewenhuijse
Postby letitbe » Tue Aug 18, 2009 7:38 pm
The problem is the PLC-BUS itself!
You can test it.
Always, when a controller checks the PLC-BUS like "Get ON ID Pulse" or sending an additional ON Command to 2263 while ON, the light is flashing.
letitbe
Postby r_255 » Tue Aug 18, 2009 8:24 pm
Hello Letitbe and welcome,
Do i understand you right that the plc controller itself is causing this problem ?
I guess thats easy yo check and put the dimmer on and disconnect the controller at one of those moments.
Thanks for your sugestion.
Thanks for the sugestion
r_255
Postby letitbe » Sat Aug 22, 2009 1:08 pm
Hello r_255,
I found a new German Forum; here you can find information about this problem. If I understand it correct, there is a communication problem with PLCBUS II R2263D.
http://www.plc-bus.info/viewtopic.php?f=11&t=5
The German PLC-BUS shop does not sell PLCBUS II R2263D any more.
I think there is something wrong with PLCBUS II R2263D.
http://www.ruvitec.de
letitbe
Postby kevinlo » Wed Aug 26, 2009 9:14 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by letitbe</i>
<br />Hello r_255,
Hello letitbe ,
Can you give me the serial number on your PLCBUSII-R2263D ?
I try to check with factory for what problem on this module.
Thanks
Kevin Lo
kevinlo
Postby gjniewenhuijse » Thu Aug 27, 2009 7:52 am
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by kevinlo</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by letitbe</i>
<br />Hello r_255,
Hello letitbe ,
Thanks
Kevin Lo
Hello, is have the same problem with this module, i can find the following numbers:
on module: P2263GF27B020
on case: 6 933211 322637
gjniewenhuijse
Postby kevinlo » Thu Aug 27, 2009 8:10 am
What is the exact model number on the module ?
Thanks
Kevin Lo
kevinlo
Postby kevinlo » Thu Aug 27, 2009 8:59 am
OK , I got the answer from R&D.
In some situation , when the PLCBUS II - 2263D receive the command and send back the ACK feedback , the light will flash.(ON - OFF - ON within 10ms )
The problem is like this :
Controller send A1 ON (need ACK feedback)
2263 receive it , then send ACK feedback <--- at this moment , it will NOT flash
Next time Controller send A1 ON ( need ACK feedback )
2263 receive it , then send ACK feedback <--- at this time , it will flash
But if the command no need ACK feedback , like ALL ON , it will not case this problem.
The problem is depend on the powerline environment . That mean even you have problem on this 2263 , but you give this 2263 to your friend , your friend may not have this problem.
R&D explain to me is the 2263 send ACK feedback command , it activate the Triac in the dimmer module .
For the solution , you can install a Noise Absorber ( 4820 ) at the L and N of 2263.
This Noise Absorber will absorb the Noise and PLCBUS signal for make the ACK feedback signal weaker for prevent this problem.
To letitbe , if you find the problem is cause by ACK feedback . you should install a 4820 at the 2263 , not at the distribution box. Then problem should solve.
To gjniewenhuijse , you need to check the problem is cause by Outside Noise or ACK feedback.
Actually 4820 is a 5uf capacitor , you should find in locally , otherwise , leave me a message .
kevinlo
Postby gjniewenhuijse » Thu Aug 27, 2009 12:52 pm
<br />
My problem is not the ACK feedback, but a noise generated by another device or something else.
i try to install a capacitor and let you know if it works (or not).
gjniewenhuijse
Postby letitbe » Sat Aug 29, 2009 8:42 am
I get definitely flashes by ACK. Always I send command from controller I get a flash.
@ kevinlo I think there must be a bug in firmware.
I also use 2026 plug-in module. This plug-in module works fine, no flashes!
4820 is not a solution for me, it is too big.[:(] I do not have the space for 4820 near 2263!
I had problems to get 2263 behind switch. It is impossible to put 2263 together with 4820 behind wall switch! I need other solution.
letitbe
Postby kevinlo » Mon Aug 31, 2009 10:36 am
To letitbe , just got the message from R&D , will have new firmware (ready in this week) for solve this problem.
You can ask your supplier for change the unit.
If you find difficulty , leave a message to me. I can exchange to you. ( If you don't mind to send your unit to Hong Kong )
Kevin Lo
http://www.x10-hk.com
kevinlo
Postby r_255 » Mon Aug 31, 2009 11:44 am
I disconnected my controller from the powerline when the flashing started and the flashing did not stop, so it must be generated by something else on the line.
i also got 2 plc plugin dimmer and 2 switches who work perfectly. They 2263 must be more sensitive some how for these signals. I also noticed the devices locked up while flashing and are not controllable. And like letitbe, i think most of us have problems fitting in the module incombination with the original switch. So also mounting a filter wil be impossible without breaking up walls.
please dont get me wrong but with the prices of these filters zwave can be a good replacement and solve the problem as good as any filter can do for me.
but again, thanx for the efforts of posting.
Robin
thanx for your efforts!
r_255
Return to PLCBUS Forum
Users browsing this forum: No registered users and 0 guests
