Cannot load class 'RpcClient': Unable to load class file
Moderator: RDNZL
bas334
Post by bas334 »
When I start Domotiga, I see this message
ERROR: #2: Cannot load class 'RpcClient': Unable to load class file
any idea what goes wrong?
Bas
RDNZL
Post by RDNZL »
Hi, did you compile gambas from src? If so it could be that you failed to install a depency. If you installed it from packages, you missed one or you have a very old verion in which rpcclient component had bugs. So which version of gambas and which os? Also check that you didn't change domotica project properties and the rpc component is still selected. Regards, ron
bas334
Post by bas334 »
solved.
I have updated my Ubuntu and reinstall gambas2
Return to “DomotiGa Forum”
