Hallo people,
I have to do some research about Z-wave and I was wondering if you could help me out ?
I need a zigbee adapter which is compatible with linux and also has a sdk. If you know a good one please let me know.
Does the ControlThink CTZUS also work with linux ?
Thanks for your help.
Kind regards.
Linux & SDK
- Starting Member
- RDNZL
Linux & SDK
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by beatboxer05</i>
<br />Hallo people,
Kind regards.
Don't know if a Linux SDK exists, but a open source working API is found here:
http://svn.linuxmce.org/svn/trunk/src/ZWave/
http://wiki.linuxmce.org/index.php/ZWave_API
This is the list with supported controllers.
http://wiki.linuxmce.org/index.php/Z-Wave
I see no ControlThink interface there though, but enough alternatives.
<br />Hallo people,
Kind regards.
- Starting Member
Linux & SDK
Thanks for the information , Do you know how to install this API on my pc ? And where can i find the codes which a z- wave system uses to interact.
kind regards.
niek
kind regards.
niek
- RDNZL
Linux & SDK
<br />Thanks for the information , Do you know how to install this API on my pc ? And where can i find the codes which a z- wave system uses to interact.
kind regards.
niek
It's not a standalone one, it belongs to LinuxMCE (open source Plutohome), so you need to seperate it from that, funny enough the developers started it as a standalone app/lib, and later migrated it, if we only could find it
I have peeked at the source code, and it's not so easy as controlling X10, but it's a better protocol too.
kind regards.
niek
- Starting Member
Linux & SDK
Thanks for the information,
Could somebody tell me what the importance is of the libary version in the specifications of the z-wave adapters and what the function is of those libaries.
Kind regards
Kind regards
