Plugwise Error
Posted: Mon Sep 28, 2009 9:57 am
Sinds vandaag krijg ik onderstaande error tijdens het opstarten en afsluiten van HS.
Plugwise modules staan wel goed in HS.
28-9-2009 9:33:32 Plugwise DEBUG: Register config change callback
28-9-2009 9:33:32 Plugwise DEBUG: Application path: C:\Program Files\HomeSeer 2
28-9-2009 9:33:32 Plug-In Initializing Plug-in: Plugwise
28-9-2009 9:33:32 Plugwise DEBUG: InitPlugin: Homeseer Interface Version: 3
28-9-2009 9:33:32 Plugwise DEBUG: InitDatabase: Entered function
28-9-2009 9:33:32 Plugwise DEBUG: InitDatabase: Opened connection to database 'C:\Program Files\HomeSeer 2\data\Plugwise\plugwise.mdb'.
28-9-2009 9:33:32 Plugwise DEBUG: InitPlugin: Read configuration from the database
28-9-2009 9:33:32 Plugwise DEBUG: Set host to localhost
28-9-2009 9:33:32 Plugwise DEBUG: Set Refresh Interval to 30000ms
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )30
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )31
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )29
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )32
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )33
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )34
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )35
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )36
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )37
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )38
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )39
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )40
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )41
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )42
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )43
28-9-2009 9:33:32 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )44
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )45
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )46
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )47
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )49
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )48
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )50
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )51
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )52
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )54
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )53
28-9-2009 9:33:33 Plugwise ERROR: InitDevices: No corresponding database entry can be found for device )55
28-9-2009 9:33:33 Plug-In Finished initializing plug-in Plugwise
- Antoon
- Antoon
