Als ik nu even een stukje log bekijk dan zie ik het volgende:
11-11-2009 8:59:55 ~!~Plugwise~!~INFO: Updating usage of XXXXXXXXXXXXXXXX ([1) from 571,3W to 590,4W
11-11-2009 8:59:55 ~!~Info~!~Event Trigger "Update value to DB"
11-11-2009 8:59:55 ~!~Info~!~Running script in background: L2DB.vb
11-11-2009 8:59:55 ~!~L2DB~!~Script running
11-11-2009 8:59:55 ~!~L2DB~!~INSERT INTO devices([date],[time],
,[status],[name],[value],[location]) VALUES('11-11-2009','08:59:55','[1','ON','Total sum','590','')
11-11-2009 9:00:00 ~!~Info~!~Event Trigger "Daglichtlamp - Inschakelen"
11-11-2009 9:00:00 ~!~Info~!~Device: 1ste verdieping Kantoor Daglichtlamp ([38) ON
11-11-2009 9:00:00 ~!~Plugwise~!~DEBUG: SetIOEx called for Kantoor 1ste verdieping Daglichtlamp
11-11-2009 9:00:00 ~!~Plugwise~!~DEBUG: SetIOEx: Housecode: [ Devicecode: 38
11-11-2009 9:00:00 ~!~Plugwise~!~DEBUG: SetState: Calling 'http://aeneas:8081/switch.html?applid=38&cmd=1'
11-11-2009 9:00:00 ~!~Plugwise~!~INFO: Set appliance [38 to on
11-11-2009 9:00:00 ~!~Info~!~Event Trigger "Update Plugwise Status - Daglichtlamp"
11-11-2009 9:00:00 ~!~Info~!~Running script and waiting: Plugwise_Status.vb("Main","[38,P38")
11-11-2009 9:00:00 ~!~PlugWise_Status~!~[38->P38 set to status 2
11-11-2009 9:00:09 ~!~Plugwise~!~DEBUG: Query: http://aeneas:8081/statistics.xml
11-11-2009 9:00:10 ~!~Plugwise~!~DEBUG: Parsing statistics.xml
11-11-2009 9:00:10 ~!~Plugwise~!~DEBUG: Timestamp: 2009-11-11 09:00:10, Source version: 20091028.0
11-11-2009 9:00:10 ~!~Plugwise~!~INFO: Status of 000D6F00003FEC88 ([38) has been changed from On to Off
11-11-2009 9:00:10 ~!~Plugwise~!~DEBUG: INSERT INTO statistics (macaddress,powerusage,powertotal,state) VALUES ('000D6F00003FEC88',0,529,3)
11-11-2009 9:00:10 ~!~Info~!~Event Trigger "Update Plugwise Status - Daglichtlamp"
11-11-2009 9:00:10 ~!~Info~!~Running script and waiting: Plugwise_Status.vb("Main","[38,P38")
11-11-2009 9:00:10 ~!~PlugWise_Status~!~[38->P38 set to status 3
11-11-2009 9:00:10 ~!~Plugwise~!~DEBUG: Update statistics for [38 in database
11-11-2009 9:00:10 ~!~Plugwise~!~DEBUG: Updating Total Device values
11-11-2009 9:00:24 ~!~Plugwise~!~DEBUG: Query: http://aeneas:8081/statistics.xml
11-11-2009 9:00:25 ~!~Plugwise~!~DEBUG: Parsing statistics.xml
11-11-2009 9:00:25 ~!~Plugwise~!~DEBUG: Timestamp: 2009-11-11 09:00:25, Source version: 20091028.0
11-11-2009 9:00:25 ~!~Plugwise~!~DEBUG: Updating Total Device values
11-11-2009 9:00:39 ~!~Plugwise~!~DEBUG: Query: http://aeneas:8081/statistics.xml
11-11-2009 9:00:40 ~!~Plugwise~!~DEBUG: Parsing statistics.xml
11-11-2009 9:00:40 ~!~Plugwise~!~DEBUG: Timestamp: 2009-11-11 09:00:40, Source version: 20091028.0
11-11-2009 9:00:40 ~!~Plugwise~!~DEBUG: Updating Total Device values
11-11-2009 9:00:55 ~!~Plugwise~!~DEBUG: Query: http://aeneas:8081/statistics.xml
11-11-2009 9:00:55 ~!~Plugwise~!~DEBUG: Parsing statistics.xml
11-11-2009 9:00:55 ~!~Plugwise~!~DEBUG: Timestamp: 2009-11-11 09:00:55, Source version: 20091028.0
11-11-2009 9:00:55 ~!~Plugwise~!~DEBUG: Updating Total Device values
Komt op mij over dat de PlugIn netjes tegen Source zegt dat het device aan moet, verolgens update de PlugIn gelijk de status van het device in Homeseer en bij de eerstvolgende update blijkt dat dit niet is gebeurd en wordt het teruggezet.
Oftewel, blijkbaar komt het verzoek om iets te schakelen via de webserver van Source niet altijd meer goed aan. Ik heb dit probleem met Source 20091028.0. Ik weet niet of ik het bij de vorige versie ook al had.
Hebben anderen hier ook last van?
