Is there any way to use this plugin when the Fritzbox password is not default?
It doesn't seem to work for me...
Change password
Moderator: RdP
Change password
What makes you think the Plugin needs a password?
It doesn't need a password [:)]
Did you dial <b>#96*5*</b> with an internal phone, so the Fritz!Box knows it has to turn on it's call monitor? Otherwise the Plugin won't work.
Change password
Until now I had to enter a password on all call monitoring applications I used on OSX. No need to dial anything so far.
I'll give it a try later today.
Change password
Works like a charm. Time to fine tune the output....
Change password
Good to hear, thanx
