Can't add Oregon sensor
Edwin
Post by Edwin »
cant add the oregon thr 128 on channel 3
did a clear heard but still the:No devices found to add line
i have another on channel 2 no problems
and a thgr 122 on channel 1 no problems
what to do?
thanks greetings edwin
b_weijenberg
Re: cant add sensor
Post by b_weijenberg »
The THR128 transmits sometimes a wrong signal after reset. The easiest way is to use RFreceiver then set the sensor to ch 3 and reset the sensor until it is received.
Edwin
Re: cant add sensor
Post by Edwin »
b_weijenberg wrote:The THR128 transmits sometimes a wrong signal after reset. The easiest way is to use RFreceiver then set the sensor to ch 3 and reset the sensor until it is received.
thanks bert i will try that.
Wim2008
Re: Can't add Oregon sensor
Post by Wim2008 »
I have several Huger BTHR918 sensors. All of them exept 1, I could read in with RFXcom till now.
The last one, I have reset him several times on several days, isn't recognize with the RFXcom.
How can I controll this last sensor ?
B.R. Wim :)
b_weijenberg
Is that sensor detected by the Oregon base station? In other words is the sensor OK?
Wim2008
Post by Wim2008 »
I haven't a base station?
Can I see or controlled that on another way?
B.W. Wim :)
