Power measurement with RFXCOM & and power meter with IR LED
Posted: Mon Dec 21, 2009 11:23 pm
by I-1
I have the power measurement part of my overall domotica setup working.
It was a bit of a pain because I had an IR Led on my (Eneco) power meter.
But I have it working eventually ... the trick with the Reflective-Optical sensor is that I had to cut the white wire in the 3,5 jack. (Not blue or the copper ... but the white wire)
More on this project can be found on my personal blog -->
http://blog.i-1.nl/?page_id=340
Re: power measurement with RFXCOM & and power meter with IR LED
Posted: Mon Dec 21, 2009 11:31 pm
by TANE
Good to see that it's working...now the next step.
reducing of the yearly usage of 15.000 kwh...
Posted: Mon Dec 21, 2009 11:33 pm
by petermdevries
Good to see that's working. I have the same power meter and also found out that it has an IR led, but wasn't for sure it would work together with the RFXMeter.
So now I know that it will work. So I think I know what will be the next thing on my wishlist
Posted: Mon Dec 21, 2009 11:35 pm
by I-1
TANE wrote:Good to see that it's working...now the next step.
I don't think that will ever happen ... especially not with 3 x DL360 G3 servers running upstairs...
Posted: Mon Dec 21, 2009 11:38 pm
by TANE
3 X macmini will do the same...
total usage 50 Watt/h
Posted: Tue Dec 22, 2009 12:09 am
by I-1
TANE wrote:3 X macmini will do the same...
A mac mini can't run ESX 3.5 heheh
Posted: Tue Dec 22, 2009 1:21 am
by TANE
Vmware ESX will run on lot of other machines...
What Vmware can do for you.. This is one of my green data-centre ideas
Set two machines in maintenance mode.
Vcenter will move the machines using vmotion to the running server
Shutdown the two machines in non rush hours..
Send WOL to the machines that are shutdown just before the rush hour or when there is need for more power.
