Extend antenna cable
Posted: Fri Aug 03, 2007 3:43 pm
by Droezel
I guess it's time for my first post!
Can I extend the 2,5m cable that comes with the antenna of the receiver? My home control server will be placed in the cellar and I guess that's not the best place to put the antenna. I'd like to replace the 2,5m cable with a new one that's about 10 meters.
So, the questions are:
* Is it possible to use a longer cable, is there a maximum length?
* What cable do I use? Just ordinairy Coax cable?
I'm looking forward to posting a lot more on this forum while my renovation project get's started. I'm good with computers but not with all the electrical and technical stuff so I'm affraid I'll need advice frequently.
Posted: Fri Aug 03, 2007 3:53 pm
by b_weijenberg
Droezel,
It is not advised to use a longer antenna cable. The Home Automation signals are very weak and the signal lost in the cable will limit the range drastic.
The cable used is an RG58 with solid core.
The Ethernet interface (LAN or WLAN) would be a better solution. This interface will become available in about 4 weeks.
The Ethernet interface can be placed at the optimum location for receiving the HA signals and away from noise sources like the computer. If the WLAN version is used the only thing you need is a wall socket and a wireless access point on your network.
Bert
Posted: Fri Aug 03, 2007 4:23 pm
by Droezel
Hmmzzzzz, just got my usb receiver... can I still use the receiver with the ethernet interface?
I'll be needing the receiver for x10 (already got that one) and one for visonic powermax.
EDIT: oh, and will it work out of the box with homeseer?
Posted: Fri Aug 03, 2007 4:43 pm
Posted: Fri Aug 03, 2007 4:52 pm
by b_weijenberg
Droezel,
The receivers are identical and can be placed in the Ethernet interface.
Install the free Com Port Redirector and it operates with Homeseer. I have a WLAN 2 COM port version operational with an X10 receiver a Visonic receiver and the RFXCOM transmitter. The receivers are connected to the ACRF plug-in in Homeseer and the transmitter is controlled by Homeseer scripts.
If you would like to do a short test, you can contact me by email and I will give an IP and port number to enable you to add my sensors here in NL in your HS system using my test RFXCOM Ethernet interface which is connected to the Internet.
Bert
Posted: Sat Aug 04, 2007 9:44 am
by Droezel
Thanks for your offer on the test, but I haven't even got Homeseer yet
And my demo period just ended.
We are now finishing electricity in our new house (actually a very old house that we're renovating). I'm sure the ethernet interface will be the perfect and flexible solution since I've installed lot's of UTP everywhere.
I think I'll go for the wired 2 COM port version with X10, Visonic and Transmitter. That combo should be able to do all I need.
Posted: Sun Aug 05, 2007 8:10 pm
by docbee
rg58 is the ham's swiss army knife but it is not really 1st choice in the 70cm band.
look a the attenuation on a 100m cable below.
MHz AIRCELL7 ECOFLEX 10 AIRCOM PLUS ECOFLEX 15 RG 58 RG 213
432 14,1 dB 8,9 dB 8,2 dB 6,1 dB 33,2 dB 15,8 dB
so rg58 is really poor performing. You can also increase signal strength with a special antenna (like a hb9cv for directional use) instead of the groundplane coming along with the rfxcom set.
