Hallo,
what means "Split Calls" in the setup of the Fritz-Plugin?
Thanks, Ralf
What means Split Calls
Moderator: RdP
Re: What means Split Calls
Hi Ralf,
Split calls means that you would like to Plugin to split incoming and outgoing calls (devices) into 2 separate ranges of HS devices.
For example x1...x10 will be the last 10 incoming calls and x11...x20 will be the last 10 outgoing calls, where x is the housecode that the Plugin uses.
If you decide not to use the "Split Calls" then all caals (in and out) will be mixed up into a single range of HS codes.
