I need some help with a json result and puting the needed data in an array.
Do we have any good PHP / JSON coders here who can give me some help with this?
It's NOT domotica releated.
If interested than please let me know.
Thank you.
Any good PHP / JSON coders here? I'm stuck!
Re: Any good PHP / JSON coders here? I'm stuck!
If you are using the right version of php you can use http://php.net/manual/en/function.json-decode.php
Rutger
Rutger
Hi Rutger,
Yes I did have a look at that page already, but for some reason it's not showing me the data in an array.
For me the returned result is all on one line.
Can you post a piece of json code that is returned, then I will try some things.
Problem solved!
Thank you Bas!
Thank you Bas!
