Packet timeout on LAN receiver
Posted: Fri Jan 15, 2010 12:03 am
by Dickr43
Today my new LAN Receiver-transmitter arrived and I installed it according the manual. Both com port are created and redirected. They both show up fine in Homeseer and all seems to be OK. I did not try to connect any sensors to the receiver because every 30 secs I´m getting this error in the log: RFXCOM(ComTimer_Elapsed) packet timeout receiver #1 State:21
What is causing this? The transmitter is working fine!
Re: Packet timeout on LAN receiver
Posted: Fri Jan 15, 2010 10:29 am
by b_weijenberg
Stop HS and try with RFreceiver in Variable Length Mode, Check if you get a response 2C in the Variable Length Mode command.
You do not need CPR and can use the IP address:10001 in RFreceiver as well as in the RFXCOM plug-in
Posted: Fri Jan 15, 2010 2:01 pm
by Dickr43
I do get the 2C return but also below messages:
2C ACK
50FFFA2C6A04FFF0A309FF bits=80
FA2C6A04FFF0FAFFFA2C6A04FFF071FF bits=122 from SLAVE
FA2C6A04FFF01155FFFA2C6A04FFF0F2 bits=122 from SLAVE
FFFA2C6A04FFF05150FFFA2C6A04FFF0 bits=127 from SLAVE
A309FFFA2C6A noise or an unknown data packet received bits=35 from SLAVE
04FF noise or an unknown data packet received bits=4
F0FAFFFA2C6A04FFF071FFFA2C6A04 bits=112 from SLAVE
FFF011FFFA2C6A04FFF055F2FFFA2C6A bits=127 from SLAVE
F051 Buffer flushed due to timeout
50FFFA2C6A04FFF0356ED4 bits=80
FFFA2C6A04FFF08517FFFA2C6A04FFF0 bits=127 from SLAVE
FA2C6A04FFF02AF650FFFA2C6A04FFF0 bits=122 from SLAVE
356ED4FFFA2C6A04 noise or an unknown data packet received bits=53
FFF085FFFA2C6A04FFF017FFFA2C6A04 bits=127 from SLAVE
FFF004FFFA2C6A04FFF02AF6 Buffer flushed due to timeout
I'm thinking that I might made a mistake in the config. I used 2 stopbits for the receiver (serial 1). Is that maybe a problem?
Posted: Fri Jan 15, 2010 4:39 pm
by b_weijenberg
Posted: Fri Jan 15, 2010 5:17 pm
by Dickr43
Thanks Bert,
The problem was that the receiver was set to 2 stop bits, should have been 1.
