Second stick or circle(plus) in the same network
Posted: Fri Jan 29, 2010 9:29 pm
by RdP
I bought a cheap second staterkit. The question is what will happen when:
- I have a second circle+ in my home ? will this be treated as a second network ??
- Can I use the second stick to connect also to my existing circle+ and retrieve the same info to another PC ??
Thanks,
Re: Second stick or circle(plus) in the same network
Posted: Fri Jan 29, 2010 9:41 pm
by Alexander
I thought the answers would be:
- Yes
- No
Posted: Fri Jan 29, 2010 9:53 pm
by RdP
Alexander wrote:I thought the answers would be:
- Yes
- No
I was afraid that was the answer... :?
Posted: Sat Jan 30, 2010 10:40 am
by TANE
Rien I have also a starter set for the case when there is any problem with the circle+ or the usb stick. Plugwise will replace the defect devices but I don't want to wait a week or longer for replacement.
Posted: Mon Apr 19, 2010 12:31 pm
by Floppe
So you are telling us that it is not possible to have 2 sticks connected to the same network?
Posted: Tue Apr 20, 2010 8:05 am
by RdP
Floppe wrote:So you are telling us that it is not possible to have 2 sticks connected to the same network?
Right....
Replacing just the Circle+
Posted: Sat Jul 17, 2010 3:13 pm
by xAPPO
I have been using Plugwise European plug versions and Stealths - over 30 devices . Now that I have some UK format plugs I wish to replace my EU Circle+ with a UK one. So is there an easy way to swap the Circle+ ie link my new one into the existing network . Do I have to factory reset every Plug and Stealth to do this :-( and I assume this will this lose all my historic data.
Also just as a general thought is it ever possible to re-purpose a spare Circle+ as an ordinary adaptor - ie two Circle+ on a network but only one used as a Circle+. I think from the above post the answer is no
K
Posted: Thu Jul 22, 2010 1:11 am
by xAPPO
Just for info the answer from Plugwise is no - you must manually reset all your circles / stealths if you replace the Circle+ - which is really laborious ....
( I don't believe there's a software way is there - would be a useful feature)
Also no.. Circle + are only useable as Circle + and only one per network.
K
Posted: Thu Jul 22, 2010 2:39 am
Just like there can be only one Coordinator per network; so this was not a thought or question, just wishful thinking :lol:
