Sony PCS-C160P
Moderator: Esteban
smst
Sony PCS-C160P
Post by smst »
Does anyone know how to connect the Sony PCS-C160P to a PC? Or, use it as a video camera/webcam?
Appreciate your help,
SMST[:)]
Sony PCS-C160P
He Dude,
That's funny, I have that exact camera!
I got it working on RS232 with full pan tilt and zoom.
I don't use the camera anymore at the moment, because I have other Sony EVI-D30 as well.
The Sony EVI-D30 is internal the same camera as the Sony PCS-160P.
What you should do is dismount the camera from the Video conferencing unit, there is a lot of crap in there like ISDN connection etc you don't want to use. After you disconnect the Camera you see 2 connectors:
You need the 15 pin connector, with this connector you can handle Video, Power and Visca control (PTZ) the RS232 protocol is the same as the SONY EVI-D30, EVI-70 or EVI-D100.
If you need more info on which pins to use let me know, I have to search for the connector, can't find it right now because of the mess in my room [:D]
If you want I a got a PDF file with all the technical specifications.
Pieter Knuvers
Re: Sony PCS-C160P
On request manual pdf file for Sony PCS-C160P
http://www.bwired.nl/images/how/PCS-P160P.pdf
_simon
Re: Sony PCS-C160P
Post by _simon »
Hi
I want to control the PTZ movements of my Sony PCS-C160P camera unit via serial and wondered if you could give me some further information on the connections? Below is what I had in mind, is this correct?
Pin 1 Y >s video pin Y Brightness
Pin 2 Y.GND > s video pin signal ground
Pin 3 C > s video pin chrominance signal
Pin 4 C.GND > s video chrominance signal ground
Pin 5 GND > 12v power supply ground
Pin 6 GND > 12v power supply ground
Pin 7 RxD > RS323 Transmit Data
Pin 8 TxD > RS323 Receive data
Pin 9 12v > 12v power supply
Pin 10 12v > 12v power supply
Pin 11 GND > 12v power supply ground?
Pin 12 SIRCS > ?
Pin 13 DTR > Rs323 Data terminal ready
Pin 14 GND > 12v ground?
Pin 15 GND > 12v ground?
Many thanks
Simon
Re: Sony PCS-C160P
its visca command
try this bwired.nl/images/how/D100_technical_man ... manual.pdf
there are also testprograms on internet for Sony the Visca commandset
